![]() Join Date: Feb 2015
Can someone identify this part:
It's on the left hand side next to radiator. Has a vac. line going to it but it's not connected to anything. No wires to it either. Sorry for the crappy cell phone pics. Thanks
Tim Yesterday is history, tomorrow is a mystery, today is a gift, that's why it's called "the present". 1971 ![]() |
Moderator
![]() Join Date: May 2007
Re: Can someone identify this part:
Looks like an aftermarket cruise control module
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I thought it was part of a cruise control but there is nothing else to go with it. It has a knob on it that turns but has no tension and looks like there is an adjuster screw with a jam nut on the other side.
Thanks for the reply.
Member #1049
I do believe it is a vacuum driven air compressor which was used in the AC Delco "pleasure lift" air shock system
Thanks for the responses guys. I am going to remove it and see if I can find a part number on it then do a search and see what happens.
Old member
That was a factory option vacum pump that would pump up air shocks off the motor vacuum. I have mine installed on the 71.
Here is a link for it. Has all the info you need. ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=559816
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Wow! Thanks Andy.
Odd thing is I only have that piece and the air shocks and they are junk. The SPID doesn't show that as an option either. Beginning to wonder what my truck really is!!
#8 | |
Old member
![]() Quote:
