Old 03-25-2015, 08:36 AM   #1
OJ1988
Just a car guy
OJ1988's Avatar
where to get shifter for 1988 5 speed
My shifter is full of slop, parts seem to be worn/missing. I am starting to have trouble getting into some gears and am hoping its the shifter and not the trans itself.
It is a 1988 1500 5 speed.
So far the only new shifter I have found is for 97 and up nad says it will not work on the older transmission.
Don't really want to spend $300 on a Hurst shifter.
Anyone know? I tried Rock auto and could not find it listed.
1955 belair Blown Pro Street cruiser
1971 Camaro Pro Touring
1973 Vega Drag Car
1970 C20 tow rig
OJ1988 is offline   Reply With Quote
Old 03-25-2015, 09:03 AM   #2
ChevyTech
Re: where to get shifter for 1988 5 speed
You may be able to fix the old shifter.
There is a small pin in the shifter that breaks and can cause what you are experiencing.
There should be a few threads about in on the board here.
Here is one of the threads I kept a link to:
http://67-72chevytrucks.com/vboard/s...d.php?t=353603
Old 03-25-2015, 09:22 AM   #3
OJ1988
Just a car guy
OJ1988's Avatar
Thanks for the info. I'll pull it out and give it a look!
1973 Vega Drag Car
1970 C20 tow rig
Old 03-25-2015, 09:35 AM   #4
ChevyTech
You're welcome!
Let us know if that was the problem.
This builds a database for people doing a search.
Old 03-25-2015, 10:15 PM   #5
OJ1988
Just a car guy
OJ1988's Avatar
One of these pins were loose. It looks like the big ring that holds them may have broke?
tgat is after I pushed the pin back on and ran the big ring back thru it.
That made the shifteruch better, but dod not fix my problem.
I drained the fluid, it looked awful.
There was What looked like a roll pin stuck on the plug with many small shavings.
Added new fluid, did not fix it.
I think my sycros are shot.
1973 Vega Drag Car
1970 C20 tow rig
Old 03-26-2015, 09:17 AM   #6
ChevyTech
I have never seen one crack like that before.
I would not fix that transmission.
I don't like the design of this transmission and would look for the newer design transmission out of a 1993 or newer truck.
Note: Don't use 80W90 in these transmissions
Here are several threads with some of my discussion on the GM 5 speed transmissions known as the Getrag.
http://67-72chevytrucks.com/vboard/s...ighlight=5LM60
http://www.chevytalk.org/fusionbb/sh...rch/1/#1484341
http://www.chevytalk.org/fusionbb/sh...9b717/#1584388
http://www.chevytalk.org/fusionbb/sh...rch/1/#2030100
http://www.chevytalk.org/fusionbb/sh...arch/1/#606955
If you do a search you should be able to find many more posts by me on that transmission.
Old 03-26-2015, 03:14 PM   #7
OJ1988
Just a car guy
OJ1988's Avatar
I've read a few of them.
I went with 5w30 mobil1 based on other threads.
Definatly don't plan on spending any more money on this transmission!
Thanks for the help!
1973 Vega Drag Car
1970 C20 tow rig
Old 03-26-2015, 03:56 PM   #8
OJ1988
Just a car guy
OJ1988's Avatar
I can't complain, transmission has 270,000 miles on it and the last 10,000 vehing a somewhat healthy 355.
1973 Vega Drag Car
1970 C20 tow rig
