03-25-2015, 01:14 PM | #1 |
Routing power steering hoses
Would anyone have any photos of the correct way the power steering lines should be routed on a 72 with a 350?
I swapped from a 250 to this 350 and these lines just don't seem right. Of course, the way that power steering bracket was designed, certainly doesn't make it easy to get to. I have them routed through the bracket. This is a K10, but I don't think that would matter? I checked on Rockauto for power steering lines, and they list the exact same ones for the 6 cyl and the 8 cyl engines
Bill 2004 Chevy Silverado Z71 Ext Cab 1500 1972 Chevy K-10 SOLD 1967 Chevelle SS |
03-25-2015, 01:40 PM | #2 | |
Re: Routing power steering hoses
Just make new ones that fit. Any local AC or hydraulic shop can shorten and re-crimp your old hose for you if you don't want to spring for the PTFE/stainless high pressure hose and fittings I used. |
03-25-2015, 02:25 PM | #3 |
Prestige Worldwide
Here is how mine is routed, its a big block so I hope this helps for reference anyway.
03-25-2015, 02:41 PM | #4 |
subbed
Figure out what you want--then figure out what you are willing to give up to get it. |
03-25-2015, 03:13 PM | #5 |
These are exactly like the originals on my 69 with 350. In fact, the steel part of the return line IS the original. First pic is routing from pump under inner fender.
03-25-2015, 03:25 PM | #6 |
Subscribed
1970 C-10 lwb, 307 V8, THM-400 1998 Camaro Z28, LS1, T-56 6 speed manual (Daily driver) |
03-25-2015, 03:31 PM | #7 |
Thanks for the photos. I think I may need to do a little fanegaling to get mine fitting properly. I'm assuming I have the correct ps bracket (I traded my 250 brackets for the 350 brackets, not really knowing what I needed) I really can't see the bracket in the photos
03-25-2015, 04:37 PM | #8 | |
EDIT: Also check out this thread. http://67-72chevytrucks.com/vboard/s...d.php?t=149210 Last edited by FirstOwner69; 03-25-2015 at 04:48 PM. |
03-25-2015, 06:19 PM | #9 |
Those photos are perfect. Thanks :-) It looks like I have them routed correct, now I just need to straighten them up a bit and track down that piece to fasten the lines to the frame.
