Anybody converted to a spin on filter?
Thinking about converting my canister filter on my '68 307 to a spin on. I was wondering if anybody had done it and how it turned out. And if you did do it and like it, what kit did you use?
Re: Anybody converted to a spin on filter?
I did it several years ago. There is a kit for it. It was pretty routine & worked real good.
![]() Join Date: May 2010
I did it on my 69 about 1972. Worked fine. I think mine used a Ford FL-1A filter. If I were near my parts stash, I'd give it to you.
#4 | |
Something like this? http://www.summitracing.com/parts/tr...2noRoCajnw_wcB |
Why? The cartridge filters have more surface area. They may be messy to change , but filter better and probably about the same cost.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
![]() Join Date: Nov 2001
I have done this on every engine I have ever owned with an OE canister filter.
Wix 24061 http://www.summitracing.com/nv/parts...4061/overview/ http://www.autopartsandstuff.com/wix...cnvrsnkit.aspx http://www.rockauto.com/dbphp/x,cata...WIX_24061.html
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
I don't debate that it is out there, but I question why you want to do it.
Does a spin on save money? Not really Does it hold more oil? No, it holds less (unless you use the big truck filter, but that has space challenges and is quite spendy) Does it have more filtering area? No, it has less (see above) Does it dress up your engine compartment? not really See excerpt from "How to Hotrod your SB Chevy". https://books.google.com/books?id=g4...tridge&f=false I'm not saying don't do it or that it can't be done. I'm just asking why you would want to.
I attempted to on my 69 short step just so I didn't have to inventory ANOTHER filter. But it leaked. So I took it off and tried again. It leaked. Once more. It leaked.
Probably 6 times I had that stupid thing on and off before going back to the parts store and buying a replacement element. Put the cannister back on, NO LEAK! Your mileage may vary, but I'm out in the future.
