Old 03-25-2015, 11:50 PM   #1
meangrean
meangrean's Avatar
Drop spindle help
Hey all. I bought 2.5 inch drop spindles from cpp. And brand new factory rotors from summit racing. However. The new factory inner and outer wheel bearings are to big for the spindles and rotors. So is there a special set of bearings i need. I phoned cpp and they couldnt seem to answer that question. For example. When i slide the inner wheel bearing on the spindle all the way. I can move it up and down on the spindle roughly 1/4". (No good). Please help figure this out
meangrean is offline   Reply With Quote
Old 03-26-2015, 07:01 PM   #2
solidaxel
solidaxel's Avatar
Re: Drop spindle help
What year truck are you working with?
Look up the part numbers they sent you and look in there catalog and see if they match.
You are right too much clearance!!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
