Gauge needles not working properly
Recently painted all the gauge needles in my '84 c10. Slipped paper behind them one at a time to protect the gauge face which seemed to work fine. In the process a few of the needles were bouncing around while positioning the paper and now aren't working properly. They work but the needles aren't positioned where they were originally. Not sure if they merely need to be re calibrated and if so not real sure how to go about that. Again, the gauges are working but the needles aren't positioned as before. Any suggestions as to how to go about correcting the problem would be appreciated.
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: Gauge needles not working properly
Have you actually powered up the cluster? It is normal for the needles to move back and forth a little and they should go back to there original position. For example, if you have a half tank of gas and you pull the cluster apart, paint the needle and it moves down to 1/4 tank, the minute you install the cluster and turn the ignition on, the needle should move back to 1/2 tank. Unless the needles are loose on the shaft or they were forced, they should go back to there original position. Make sure you have a good ground to the cluster harness. Do all of the gauges read incorrectly? Hope this helps, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
All I did was remove the lense, slip the paper behind the needles (thin paper) and paint. The ones not working properly are oil pressure and fuel. Oil pressure was running about 30 before painting and now is maybe 40 or so. Moves a Lille but not much and never zeros out.
#4 | |
Cluster King
The oil pressure would increase by 10 psi easy from a cold engine to a warm one. The fact that it does not return to zero with the key off, makes me think you are having a issue with the ground. If you can reach up behind the cluster and wiggle the connector and see if that changes anything. Also wondering if the needles got spun around in a circle (360 degrees ) more than once or twice? They do not like that and it can cause damage. Keep me posted. Take care, Tom
Hey Tom, all I did was remove the lense (left the cluster connected), slipped the paper behind each needle and painted them. The ones not displaying correctly are oil pressure and fuel. The oil pressure is not returning to zero (seems like it did before) and the fuel is pegged at full (maybe 3/4 tank actual). When I shut the truck off the fuel actually reads correctly but pegs to full when I start it. Wondering if maybe I didn't just move them on the shaft while painting. They definitely bounced around a good bit when the paper touched them. Thanks
They bounced around some but definitely no 360s. Is it possible to merely remove the needles and slip them back on in the positions they likely should be in? Could I have just moved them on the shaft during painting? I haven't touched anything else on the cluster. In hindsight i should have noted the needle positions before I messed with them. Hey, if nothing else they sure look good!
Thought for a second I might be able to help you out. I then realized your question was about an `84.
I own 3 classic vehicles. 1971 LWB C10 Deluxe. 1974 VW Super Beetle. 1971 VW Fastback. The C10 and the Super Beetle run, the Fastback is just not there yet! Please visit my Super Beetle and Fastback profile on TheSamba. |
Hey - appreciate the thought nonetheless. Haven't messed with for fear of messing them up worse and figure I've got bigger fish to fry with this ole dude. Love my truck!!
Moderator
![]() Join Date: Jun 2008
I moved this over to the correct area for you. Good luck on your troubleshooting. Hopefully, here, someone with a similar experience with a cluster like your will chime in and offer some insight.
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
Super - thank you.
