03-26-2015, 10:11 AM | #1 |
plug n play headlight relay upgrade kits....!
I have two style available now:
Stock type relay upgrade $139 Stock type relay upgrade w/adj. delay off $169 H4 style same cost just let me known if sealed beam or other. These use your existing connectors! |
03-26-2015, 10:02 PM | #2 |
Re: plug n play headlight relay upgrade kits....!
Money sent!
03-26-2015, 10:17 PM | #3 |
Thank you sir! Your kit will be shipping out by this weekend!
03-28-2015, 08:29 AM | #4 |
Tell us more about the delay off and the H4 options. I have a pair of the single 7" square Hella H4 housings that take the replacement H4 bulbs.
Also are there any open terminal slots in the bulk head connector or is it full? Looking into a Gentex two wire compass temp probe option/mod from the GM400 series vehicles.
03 Suburban Z71 Z71 98 GMC Yukon SLT 4x4 Yukon 86 M1009 CUCV Project Milverado 48 Willys CJ2A 48CJ2A Last edited by 48cj2a; 03-28-2015 at 08:50 AM. |
03-28-2015, 01:31 PM | #5 |
No....bulkhead is full BUT-I can supply you with a full replacement front lighting harness if you want with or without turn and parking lights. There are several ways I can assemble a harness for you.
03-28-2015, 06:44 PM | #6 |
The H4 bulbs require switching the ground and low beams terminals in your stock headlight connectors. The delay module is solid state with a potentiometer. There are (4) DIP switch settings and depending on which setting you choose allows for up to 900 seconds of delay off. For each setting you can adjust the time of the delay off by turning Tue potentiometer dial clockwise for more delay or counterclockwise for less delay. I usually set the headlight delay off for 30 seconds but you can easily adjust it to whatever time you want.
04-05-2015, 10:07 AM | #7 |
Ttt
06-05-2015, 05:29 PM | #8 |
OEM Delphi 2-cavity headlight connectors have been discontinued....if you want an OEM quality height kit, let me know while supplies last. Once the last of the Delphi connectors start to dry up aftermarket connectors are all that will be left. I stock/use only Delphi parts so you can be assured my kits are as high quality as you'll find-and I offer custom built harnesses for virtually any combination and can offer custom integrations into a factory appearing harness for a plug n play install! PM me for more info/questions! Thanks guys!
10-01-2015, 05:08 PM | #9 |
Also available for 81-up trucks as well. On some applications, I now also offer auto-off headlights on restarts as well as integrated auto-on headlights using an OEM style electric photoeye circuit which works in parallel with your stock headlight switch.
