Old 03-26-2015, 02:04 PM   #1
tsdashner
tsdashner's Avatar
1969 GMC half ton lowering question.
Looking at lowering my 1969 gmc and had a few questions. The truck has rear leaf springs on it. I have seen the lowering leaf springs on ece and wanted to know if anyone has installed these on there vehicle. Do you need to c-notch the frame with them. Also would it be easier to swap to a rear coil spring rear end on it? Any info would be nice. Thanks
tsdashner is offline   Reply With Quote
Old 03-26-2015, 07:47 PM   #2
Mike C
Mike C's Avatar
Re: 1969 GMC half ton lowering question.
My '69 Chevy short step is a leaf spring truck. I did not use the leafs but a DJM flip kit which puts the rear axle on top of the springs. I used CalTrac bars for bottom plates instead of the ones that came in the kit. I spent the same in the end but consider the CalTracs were included feel I came out ahead. The flip lowered the rear 7" and I relocated the sock mount to the unused hole in the OEM setup. I drilled it out and used a mount from a new set of KYB fronts. No C-notch. Cut the overload "plates" off the axle housing and put 1/2" poly bumstop on frame for occasional smacks.
I have front KYB's all the way around. Front is 2 1/2" ECE disc spindle and 2" springs. 17x8 4.5" bs 235 55 17 in front 17x9 5" bs 275 55 17 rear.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 04-20-2015, 11:48 PM   #3
tsdashner
tsdashner's Avatar
Thanks for the info. I am still unsure how much i want to lower it so i am just trying to get as many ideas as possible so i can decide from there Thanks
