Old 03-27-2015, 08:52 AM   #1
rs74
rs74's Avatar
Any lifted truck pics?
Thinking about throwing some factory wheels back on this truck I just bought with some tall/skinny tires. It has 315/75/16's now and I don't care for the offset. I want them to tuck back under the truck again and try to save the paint. So I am looking for ideas. Maroon truck is mine how it sets now and the black truck is what I am going after. I am limited on sizes if I go to 18's because I want a white lettered tire. So if you have anything like that post up a pic of if there is a link somewhere.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 03-27-2015, 08:54 AM   #2
enaberif
Re: Any lifted truck pics?
Black truck is probably running 245 or 265 tires which is why they don't stick out. 315s are a wide tire.
enaberif is offline   Reply With Quote
Old 03-27-2015, 09:06 AM   #3
rs74
rs74's Avatar
From what I looked up the rims are 18" Cadillac wheels and the guy who owned it just stated that they were 35's. I see that in the height but they don't look 12.50 wide to me. I like the look, just have to figure out what combo it is going to take to get there on a factory wheel. I have been looking at newer 2010+ wheels.
Roy
1987 R10 shortie
Old 03-27-2015, 11:14 AM   #4
JGood
JGood's Avatar
Could a guy put on fender flares or do they make them for the step side? Or is that an option?
1986 Chevy Silverado LWB (project)
1967 Chevy SBSS (future project)
2003 Chevy Tahoe (wifes daily)
2004 GMC 2500 Duramax (company truck)
1986 GMC Wrangler LWB (newly acquired beater)
JGood is offline   Reply With Quote
Old 03-27-2015, 11:16 AM   #5
JGood
JGood's Avatar
Kinda Like this?
Old 03-27-2015, 07:49 PM   #6
rs74
rs74's Avatar
Really not into the fender flares.
Roy
1987 R10 shortie
Old 03-27-2015, 08:47 PM   #7
xRAY76
just looked at that truck on CL...
xRAY76 is offline   Reply With Quote
Old 04-30-2015, 06:49 AM   #8
Boats&Hoes
Boats&Hoes's Avatar
If I was in your position, I would first deal with that rake on the rear of the truck. Hopefully there isn't a body lift on there...as far as tire, I think you may be better off with a 295/75/16. The 295 is a lil closer to a 34'' tire and less width then what you are currently running right now. It'll definitely fill in those gaps better.
Boats&Hoes is offline   Reply With Quote
Old 04-30-2015, 01:49 PM   #9
rs74
rs74's Avatar
I think I am just going to take the lift off and either go back stock or find a good riding 2.5" lift. There is no body lift on it. It has this kit here: http://www.superlift.com/lift-kits/6...-lift-kits.asp with 5" springs and blocks. It sits higher than I like and is rougher riding than I like. I got a good deal on another set of 315/75/16's but I haven't mounted them yet. Will probably just see about trading the lift and wheels off or something.
Roy
1987 R10 shortie
Old 05-04-2015, 05:08 AM   #10
Boats&Hoes
Boats&Hoes's Avatar
Well you do not necessarily need to go back to stock in order to get a good ride...The best way is also affordable!
Pair up a new set of torsion keys (Ready Lift) with a good pair of shocks like Bilstein. You'll retain the factory torsions as you will just be switching out the keys, you'll be able to run a bigger tire, and the ride will be better than factory. Personally I believe that's the cleanest look for this truck with having a good ride.
Old 05-07-2015, 10:58 AM   #11
rs74
rs74's Avatar
Funny that you say that. I have been considering a 2.5" key set. I was looking at the set that comes with the keys and 1.5" lift blocks for rear. I assume that is a leveling kit. I am looking at different brands to see what they offer. I need to start finding the stock pieces to go back on. I will need rear springs and I believe the lower control arms have been replaced. I am not sure if they are same as stock but they look like they might be longer making the tires stick out farther but that could just be me. I need to look into them a little longer. I they have SMV stamped into them. I can't really find anything on the web about SMV.
I bought some new 315/75/16's for the truck but haven't put them on yet. I will probably just try to sell or trade them off. I imagine I will buy some 8" rims instead of the 10" it has now and just run a 285/75 or may a 255/85. Something along those lines. Nothing drastic. Oh and I was thinking Bilstein as well. I had them on my 91 Z71 and really liked them.
Roy
1987 R10 shortie
Old 05-11-2015, 09:51 AM   #12
rs74
rs74's Avatar
Well I won't be taking the lift off. I called Superlift and talked to their tech. I was told that there would have had to been some trimming of frame mounts and upper control arms in order for this lift to go on. So I guess I will be putting a couple new upper ball joints in, alignment, put the new tires I have for it on and go from there. I don't really want to sell the truck but unless I want to swap the whole truck over to another frame I am not seeing much other choices. I guess time will tell what I will do.
Roy
1987 R10 shortie
