Tach location...
Would like to see some pics of steering column mounted tachs and how to attach them. I've been getting the itch to get one...thanks Ed
Re: Tach location...
I attached mine with a hose clamp. Kind of a for now thing, but it doesn't look bad.
![]() Join Date: May 2014
Here's mine...
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
They just come with a big hose clamp... its not a pretty setup... but it works I guess.
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 |
Yeah it's pretty crappy. But I like it because it's just how someone would've slapped one on it back in the 70's or something. I had originally purchased an old 70's sun tach but it didn't work. So I bought a brand new sunpro. It looks mostly the same. I could've swapped the internals into the old housing but I didn't feel like possibly ending up with 2 bad tachs LOL
#6 | |
Heres where I put mine
zibs71 Last edited by zibs71; 03-27-2015 at 10:00 AM. Reason: wrong pix |
![]() Join Date: Mar 2012
why would you guys just not do a upgrade to a OEM style in dash tach, it does not take long to install one
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks ![]() |
I'm personally not a fan of the stock tach. The double digits look weird. That's just me though. I'd like to find a retro looking tach to fit in the dash eventually.
Personally Im going with this setup except Ill be using the full sweep gauges instead.
You can buy the full setup or piece it together for a few bucks less.
The full sweep gauges and the carrier is costing me about 1100 bucks I think all said and done. Ebay the c10 gauge cluster and they come up with all different gauge packages.
#13 |
holy crap $1100 for a gauge cluster? it better be really carbon fiber and silver gauges lol
#14 | |
Hell, Im putting thousands and thousands in every other part... so what not in the dash too?
"Hey... its only time and money right? Just do it." 67 Short Bed under major construction http://67-72chevytrucks.com/vboard/s...=651356&page=8 Last edited by Possmguts; 03-27-2015 at 01:18 PM. |
#15 |
![]() Join Date: Sep 2007
cost.
1967custom |
#16 | |
#17 | |
http://shop.classicinstruments.com/1...-truck-package
#18 |
Thanks guys for your suggestions and ideas, man there's a bunch of nice rides out there...
#19 |
Cheap and easy, used Advance Auto's online discount and picked up in store...until I restore my gauges and add factory tach.
Life is too long to go slow... ![]() 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
