Old 08-28-2003, 01:03 PM   #1
Chevelle454
Chevelle454's Avatar
Engine Rebuild Kits
Where is the best place to purchase an engine rebuild kit? I am rebuilding the '72 350 very soon in school. I want to get a complete kit, new pistons, rings, bearings, valves, everything... I need a good quality kit at a decent price.
Scott
1972 C10
1972 C20
Chevelle454 is offline   Reply With Quote
Old 08-28-2003, 01:11 PM   #2
lukecp
Formerly yellow72custom
lukecp's Avatar
Northren Auto Parts has the rebuild kit for the shortblock for $154 with good quality parts too....not sure on the website. Do a search and it will come up.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 08-28-2003, 01:13 PM   #3
67sub
67sub's Avatar
Try Northern Auto Parts. Last one I bought for a 350 was like $155. Pistons,rings, bearings, cam kit, gaskets,oil pump, timing chain. Might be worth a look.
northernautoparts.com
2004 Kawasaki KLR
Always looking for a cheap driver
67sub is offline   Reply With Quote
Old 08-28-2003, 02:05 PM   #4
shortbed70
shortbed70's Avatar
I used northern in my motor and I turn it 6200-6800 with cast pistons. If you want to upgrade and get a better cam kit you can for like 35.00 more 1-800-834-0884or northernautoparts.com
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 08-28-2003, 02:10 PM   #5
Chevelle454
Are those good parts though? $155 seems pretty cheap for a complete rebuild kit. I spent over $250 on my 200cc dirtbike. I want to upgrade the cam, oil pump, and gaskets(maybe pistons?). That would put me at about $250. I want something that is going to last and stand up to alot. I am planning around 350-400 HP.
1972 C10
1972 C20
Old 08-28-2003, 02:40 PM   #6
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I have the kit from Northern Auto. I can say that not everything in the kit in best quality.
The only things that I didn't use in the kit due to quality was the timing chain ( OEM replacement nonroller), the cam because of the grind it had.
But everything else is in my motor.
Good Kit for the money if you ask me
67Fleetsidedream is offline   Reply With Quote
