Old 03-27-2015, 11:34 AM   #1
hemi43
hemi43's Avatar
How are the 1/4 panels joined in the door area?
Just going over my Blazer I picked up last week, and getting ready for a frame off restoration. I noticed that the 1/4 panel is stick welded to the door jamb and was wondering is the panel had been replaced at one time? I've worked on many cars over the years, and usually the 1/4 is spot welded in this area.
hemi43 is offline   Reply With Quote
Old 03-27-2015, 12:04 PM   #2
1rippen6
Re: How are the 1/4 panels joined in the door area?
Defiantly spotwelded but I think there are a few weld also down the ends
1rippen6 is offline   Reply With Quote
Old 03-27-2015, 12:43 PM   #3
hemi43
hemi43's Avatar
I'm just wondering if this was a repair done on the factory floor?
Old 03-27-2015, 02:14 PM   #4
turp mcspray
turp mcspray's Avatar
My factory paint Blazer, has the same uglyness in the jambs.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 03-27-2015, 02:47 PM   #5
hemi43
hemi43's Avatar
Thanks for confirming that ! I will be putting seam sealer in this area anyway, so it's no big concern.
Old 03-27-2015, 04:50 PM   #6
1972 Jimmy
1972 Jimmy's Avatar
My jams are welded in the exact same spot as well.
1972 Jimmy is offline   Reply With Quote
Old 03-27-2015, 05:14 PM   #7
A1971Blazer
A1971Blazer's Avatar
If you look in the factory assembly manual, there are several areas that are specified to be "electric" welded. This is probably of those areas but the bedside can be unbolted, a few welds and spot welds cut out, and removed as a complete assembly.
A1971Blazer is offline   Reply With Quote
