03-27-2015, 12:18 PM | #1 |
Dallas Break Line Flaring
I really don't like flaring lines with the El-Cheepo unit I have. Does anyone in the area have, or know someone who has a mastercool or eastwood style flaring tool in Dallas. I would be happy to drive over and bring some liquid refreshments to borrow for a few minutes. I need to do about 4 or 6 flares and I'll be done.
Or does anyone know of a shop that will do it? Most of the ones I have called don't really want to help me out.
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress) 2015 GMC 2500 Duramax (Daily Driver) 1999 Jeep TJ 2010 Harley Street Glide Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981 |
03-27-2015, 01:05 PM | #2 |
67-72 parts collector,…
Re: Dallas Break Line Flaring
Personally I would just purchase your own brake flaring tool.
I have one that I bought when I was about 18 years old. Still works great and has made a bunch of flares over the years. I recently purchased the Eastwood $200+ flaring tool. Best I have ever owned. Wish I would have bought one years ago.
03-27-2015, 06:20 PM | #3 |
if you were in the Houston area i'd loan you my eastwood. yep it wasn't cheap but was worth it
1967 C10 lwb two tone, 305 & rat fink style floor shifted 700r4, 20" steelies 2004 2500HD utility bed aka Brutus |
03-27-2015, 06:40 PM | #4 |
I think the pep boys in mesquite will do them.
03-27-2015, 07:02 PM | #5 |
Yes. Buy a good kit. I have good success with the Ridgid #345-DL.
>> http://www.coastaltool.com/hand_tool...aring_tool.htm [edit] Also know that annealing the line with a small torch makes the job much easier. Often times the lines get hard spots from the production process. Or at the end when you use a tubing cutter. Heat will damage coatings of course. Also, I switched over to using NiCopp (nickle copper) tubing. Expensive but very easy to bend & flare.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed. Last edited by GRX; 03-27-2015 at 07:08 PM. |
03-27-2015, 07:40 PM | #6 |
I bought mine at Sears for about $60, it works fine, just don't over tighten the thing when making the inverted flair.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
03-27-2015, 11:13 PM | #7 | ||
"I ain't nobody, dork."
I have the same one made by Craftsman you probably do swamp rat... bought it at Sears years ago. Have made lots of flares in brake and fuel lines without a problem.
Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
03-28-2015, 09:57 PM | #8 |
Oh, alright. I'll go buy another one. Can't garuntee that I'll buy a $300 one though. I may go for the rigid or craftsman model. Thank you guys.
