Old 03-27-2015, 06:54 PM   #1
pointer80
pointer80's Avatar
will 79 and 84 interchange?
Hi I was wondering if sheetmetal off a 84 2wd will fit on a 79 4wd (front end, bed etc.) Will them years interchange? Thank you.
pointer80 is offline   Reply With Quote
Old 03-27-2015, 09:42 PM   #2
jgorzitza
Re: will 79 and 84 interchange?
fit yes, small changes though. turn signal lights on the front fenders will be horizontal instead of vertical. the hoods are different. some others. i found the differences pretty quick on google
jgorzitza is offline   Reply With Quote
Old 03-28-2015, 02:44 AM   #3
andrewmp6
With the bed the earlier years used a gas cap on the side and the later years used a gas door,You can swap beds but you need to swap filler necks they are different between the gas cap and gas door styles.
andrewmp6 is offline   Reply With Quote
Old 03-28-2015, 07:30 AM   #4
motornut
78K & 79C Jimmys
motornut's Avatar
I believe 79 is the first year for gas door
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
