03-27-2015, 07:18 PM | #1 |
69 C10 700r4 non-tilt Shift Indicator
PROBLEM: I have this goofy indicator setup from the PO (see pic) where my indicator housing and lens are from a pre 70 model and my actual indicator is from a 71-72.
Everywhere I've looked doesn't sell the lens for a non-tilt. Should I swap the indicator, or the housing/lens so that they match years, and then search for a 4spd lens? Is a 71-72 indicator the same length as a pre 70 model? My 71-72 indicator measures exactly 2 1/2" from the front to the mounting hole. Is a pre 70 lens and housing the same size as a 71-72? My pre 70 housing measures exactly 3" mounting hole to mounting hole. The indicator lens measures 2 11/16" wide and 3/4" tall on the edge. Any help is appreciated. THANKS! |
03-27-2015, 08:19 PM | #2 | |
Re: 69 C10 700r4 non-tilt Shift Indicator
03-30-2015, 06:58 PM | #3 |
Ok. Thanks. I wasn't getting alot of responses so I just figured everyone didn't want to read through my other stuff going on in that other thread. And some of the other threads on the subject referenced knowing a guy who knows a guy, etc etc but they were from a decade ago.
Anyways, its good to know that the bolt holes are the same so that I can make some decisions on what to go with. Last question: Is the indicator (not the housing) for the pre-70 model the same dimensions as the 71-72 later one (will it bolt to the same hole like the housing does)? Last edited by lasmith03; 03-30-2015 at 07:01 PM. Reason: I see where you answered some questions in my quote. |
03-30-2015, 07:05 PM | #4 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=519811 |
03-30-2015, 07:39 PM | #5 |
I sanded mine down, using various grits of sandpaper leading up to 25000 grit. You can buy a polish kit in the modeling section of a hobby lobby if you have one.
03-31-2015, 09:22 AM | #6 |
Thanks. Do you know if the indicator (not the housing) for the pre-70 model the same dimensions as the 71-72 later one? Meaning does it bolt to the same hole as the 71-72 that I currently have?
03-31-2015, 10:11 AM | #7 |
The mounting holes are the same but the lens and plastic housing are totally different in size and shape. The plastic housing is taller and I feel it has a goofy appearance when compared to the metal housing you have pictured.
03-31-2015, 10:34 AM | #8 |
Ok. I'm confused. I thought I had an early model housing and a late model indicator. Am I wrong? Currently, this indicator sticks out above my housing. Thats why I wanted to switch the indicator to the earlier one if it was not correct. So I'm trying to figure out if its a direct replacement. ?
04-01-2015, 01:56 AM | #9 |
Sorry, I meant indicator. The indicator housing for the later plastic housing is taller and the orange lens marker is larger. They still mount in the exact location of one another.
04-01-2015, 08:54 AM | #10 |
Awesome. Thanks for all your help!!!
