Old 03-27-2015, 08:53 PM   #1
JayDubBlazer
go cyclones
JayDubBlazer's Avatar
Jack stand points for removing rear axel
So I am removing my rear axel to rebuild my 43 year old axle. I was under there yesterday trying to place my jack stands and couldn't find a good place to put them that would still allow me to take my axle off. I have four jack stands but none of them reach the frame. How best to stage these, but still allow me to remove the axle.
Thanks,
Wes
Wes
PROJECT OLE GREEN
1972 Blazer 4X4 350/700R4
2017 Silverado LT
JayDubBlazer is offline   Reply With Quote
Old 03-27-2015, 09:09 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: Jack stand points for removing rear axel
I'd get some bigger jackstands to reach the frame.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 03-27-2015, 09:46 PM   #3
x2. I always keep small for under axle and large for under frame on taller trucks. I place stands under frame in front of leaf spring mounts or same area on coil spring trucks
Old 03-27-2015, 11:47 PM   #4
bronze 72 super
bronze 72 super's Avatar
I have three sets that I use. My largest are rated for 3 tons plus, these are tall ones for putting under the frame, just forward of the axle. I always put a floor jack under the center section to lower the axle. This method works good for me. If you can't get the height block the stands up with good 2x6 blocks. Always have a helper there too.
bronze 72 super is offline   Reply With Quote
