2 12bolt housings w/gears
I've got two rear ends I need to get rid of one has a richmond 4.56 gear but the carrier is trash. Housing is cracked but gears ok. The other has an open 3.73 gear mostly complete but needs new bearings and seals. They must go I'm tired of them taking up usefull space. asking $50 dollers for the richmond and make offer on 3.73.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Is the 4.56 a 12 bolt truck ? with a series 4 carrier...If so I would like to buy the gear set
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications click the clicky to join the site.... http://67-72chevytrucks.com/vboard/payments.php 67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44 Anderson,CA |
Soory it took so long to get back my internet got shut off. I'm not sure on the carrier but it is a 12 bolt truck rear. It came out of my 65. The carrier isn't in the gratest of shape it broke the cross pin bolt and broke the spider gears(2) The gears seem to have no vissible damage thats why I'm selling for 50. You would probably want to take it appart and look at it closer because whomever set it up had too much play in the pinion gear and it rubbed the carrier.
