Cold starting/running problems
Hey all,
Lately I've been having trouble with my truck in the colder weather. It's always coughed and back fired quite a bid driving it in the really cold weather but it would get by. Lately, I can't even get it started or keep it running in the colder weather. However if it's more than 60 outside or so it seems to start right up and run like a top. It's kind of weird. I am not sure if it's carburation or electrical. I kind of suspect carburation. It's a stock 4b Rochester carb. Any ideas on where I should start or some basic checks?
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles. TREASURER, Drum Brake Club. |
Re: Cold starting/running problems
check your choke. do you have an auto choke or a manual?
Auto choke. It is closed when cold. It also has stock distributer.
stock distributor as in pointsand condenser?? set the points for the proper gap and or dwell
Sounds like you have to adjust the choke rod or the vacuum break for the choke.
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
