![]() Join Date: Oct 2012
1966 steering column
I have a quick question about my 66 auto column. I installed the steering wheel and tightened it up and it rubs the piece behind it. When I turn the wheel back and forth the shifter and moves with the wheel like something is loose. Does this make sense? Can I tighten something or is this just the norm?
http://67-72chevytrucks.com/vboard/s...d.php?t=548705 |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: 1966 steering column
The column has some attaching screws under the dash to adjust the tube back and forth, maybe this would help.
Norm
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
They are tight. Thanks for the idea.
I think ideally you would take it all apart and reassemble it, which is not that big a job. You might find some worn out parts. There are some adjustments that can be made with the slotted retainer, clamp and spring at the bottom of the column.
#5 | |
1965 C10 Project |
I found it at a swap meet and I payed 50 dollars for it.
