Old 03-28-2015, 07:11 PM   #1
Ohio mike
POL motor mounts
I bought the tubular motor mount and tranny crossmember kit from POL for my 67 c10, looks nice but the rubber motor mounts look kinda cheap. Uses the newer style mount. Anybody used them? Any good? I'm thinking maybe I should go ahead and buy a good pair of mounts. Something I thought seemed odd is not one of the existing holes in the frame line up with the tubular frame mounts. No big deal I guess.
Ohio mike is offline   Reply With Quote
Old 03-28-2015, 10:37 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: POL motor mounts
I have a set on my '67 Panel. You have to notch the frame so the holes line up. If you don't the rubber block mounts won't line up with the frame brackets.... Here are a couple of pictures of how I notched mine.
LockDoc
Leon
Old 03-29-2015, 05:01 PM   #3
Ohio mike
I appreciate the pics. That's easy enough. Did you use the motor mounts they sent?
Old 03-29-2015, 09:30 PM   #4
LockDoc
LockDoc's Avatar
Yes I did. I had a problem with the passengers side frame mount not wanting to sit down tight to the frame, so I egged all of the bolt holes out a little and everything fell into place.
LockDoc
Leon
