![]() Join Date: Feb 2015
3 speed transmission swap will it work
I have an early model 67 c10 with a straight six and a three speed on the column. I found a newer style three speed out of a 70 model that has a V8.
Both trucks are two wheel drive. Does anyone know if this would be an easy swap or if it will swap at all? Any information would be of great help. Thanks so much, Jake |
Re: 3 speed transmission swap will it work
I Think it is the same thing, but others will say also. Jim
![]() Join Date: May 2014
It's a different transmission, I do know that.
1967 C10, LWB, 250, Powerglide, PS, PB, 3/4 STATIC DROP |
I am a Referee of life.
Check length but IIRC, they are almost identical but the later trans had syncro low. I don't remember what year that started.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Thank you all for your help.
I don’t believe that the bell housing would switch from a V8 to an IL6 and I was unsure if the driveshafts were the same. |
The bell housing, flywheel, clutch and all from an I6 will fit a V8 since 1967. I know because I did it with a 1967 Chevy van. Dropped in a 283 in place of the I6.
Terry Soon to be retired and moving to Bristol, TN. |
