Old 03-28-2015, 08:47 PM   #1
1moretoy
Lowering blocks w/bags
Hey guys getting ready to put the rear end together and need some help with the air bag set up. Rear has a c-notch, accuair e-level, and slam ss7 bags. I have been told I should put in 2" drop blocks so I can obtain a lower ride height with the correct bag pressure. Does this seem right? I definitely dont want the rear to look like a 4x4 while cruising. Also do I need rear bag brackets or do the bags mount straight to the frame and trailing arm? Do any vendors here sell the blocks if recommended?
Thank you
1moretoy is offline   Reply With Quote
Old 03-28-2015, 09:08 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Lowering blocks w/bags
Contact member/vendor way2lo2 for lowering blocks.
http://67-72chevytrucks.com/vboard/s...d.php?t=454824
Keith
Convert to disc brakes.
Old 03-28-2015, 09:44 PM   #3
1moretoy
Do you recommend the blocks?
Old 03-28-2015, 09:50 PM   #4
lolife99
lolife99's Avatar
yes
Keith
Old 03-28-2015, 10:12 PM   #5
nlped
nlped's Avatar
I have them from him too. Great pieces.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
