Old 08-28-2003, 03:05 PM   #1
68Custom
Hammer On!
68Custom's Avatar
Angry Front End Squeak
I was wondering if there is a special grease for control arm shaft bushings. I have this horrible squeak and have had it ever since i rebuilt my front end and i can't get it to stop Ive tried greasing, using liquid lubricant but nothing seems to work... any ideas on what could be causing this problem?!? Any help is appreciated!
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 08-28-2003, 03:39 PM   #2
cdowns
cdowns's Avatar
check your upper and lower shock mounts
Old 08-28-2003, 03:45 PM   #3
dubie
dubie's Avatar
If you have a sway bar, check the bolts again for tightness. Also check the busings for wear
My name's Tim and I'm a truckaholic
My 56 Chevy shop truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=562795
dubie is offline   Reply With Quote
Old 08-28-2003, 04:37 PM   #4
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
This sounds stupid but, check your inner fender bolts.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 08-28-2003, 04:40 PM   #5
COBALT
COBALT's Avatar
No, that doesn't sound stupid. Mine drove me crazy with that rattley-squeak until I found out a couple were loose.
...and yes, the shock mounts can make noise too. Very annoying.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 08-29-2003, 05:05 AM   #6
Hotrod70C10
Low & Slow
Cobalt, I was hoping that I wasn't the only one that this had happened to!
4.5/6 drop
