ECE super track bar & shock relocation
WOW! What a difference in the ride... I bought this truck with a 2/4 drop on springs and the ride was terrible.. Got rid of the pan hard bar and added a ECE super track bar and the shock relocation kit. I also added belltech Nitro drop 2 shocks. All I can say is the ride is 100% better. Here is a pic when I was getting the tail pipes relocated to allow the track bar to fit
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 Last edited by hdff; 03-29-2015 at 10:33 AM. |
Re: ECE super track bar & shock relocation
And after the left side tail pipe was relocated. I don't know why it is upside down
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Passenger side
![]() Join Date: Jan 2011
I have the same setup under my 66 and using a different shock and it was also a big improvement. Did you use the bell techs on the front also?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
Yes I did. Since I had just bought the truck I didn't know anything about the shocks or if they were for a lowered truck so I replaced them all. I found them as a set of 4 for the truck
![]() Join Date: Sep 2007
i have the same ece setup in my 67 shorty. i havent driven it yet but glad to know the rides going to be good!
1967custom |
After reading how your truck rode I looked into the Belltech shocks. I put the full set of street performance shocks on mine and they are really nice for ride and control.
Jimmy
Did you use the supplied lower mount stud from ECE? I was trying to install this exact setup on my '69 and the stud was too big for the pin bushing. Also, I wasn't able to finagle the upper shock bushing into the upper mount. Any suggestions?
No I didn't use the lower mount bolt it was to big but they supplied extra bolts with extra washers to use as spacers that worked fine. My top perch was tight also and had to be persuaded open a little bit with a pry bar so the top shock bushing would fit
I stuck mine in the milling machine and used a piloted counter bore to open the sleeves up to 5/8 to fit the ECE studs. Looked at using just grade 8 bolts but with it in single shear figured it might move in the hole some. Liked the idea of the shoulder bolt to support the lower end of the shock.
Jimmy
#11 | |
