Old 03-29-2015, 12:58 AM   #1
Mapearso
Hood Insulation Ideas? What Do You Use??
I would like to install some hood insulation
The aftermarket suppliers prices I've seen are pretty outrageous -- like $175 plus oversize shipping
What are you guys using for underhood insulation?
Thanks!!
Mapearso is offline   Reply With Quote
Old 03-29-2015, 09:46 AM   #2
Re: Hood Insulation Ideas? What Do You Use??
Factory spec.
Old 03-29-2015, 03:46 PM   #3
Lou Boffa
Lou Boffa's Avatar
Lowes foil insulation and 3M spray adhesive.
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 03-29-2015, 08:40 PM   #4
Mapearso
Is that duct insulation? I think it's called Frost King?
If so... I've used it on the inside of the cab instead of Dynomat
Old 03-29-2015, 08:47 PM   #5
BruthaMan
US Army Veteran
BruthaMan's Avatar
I have to ask...what is the advantage to insulating the underside of the hood? I can appreciate cab insulation, but would like to learn the benefit of doing the underside of the hood.
BruthaMan is offline   Reply With Quote
Old 11-07-2016, 08:54 PM   #6
Jim70Chevy
Jim70Chevy's Avatar
Lou, If you don't mind telling me where did you get the Chevrolet radiator support covers?
They look great.
"Every professional was once an amateur who didn't give up"
My build 1970 Longbed CST/10
Jim70Chevy is offline   Reply With Quote
Old 11-07-2016, 09:20 PM   #7
Andy4639
Old member
Andy4639's Avatar
Question Re: Hood Insulation Ideas? What Do You Use??
BruthaMan,
I've never figured out why you want to hold the heat under the hood either. I have always wanted the heat to get out instead of keeping it in.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-07-2016, 09:26 PM   #8
crakarjax
crakarjax's Avatar
The insulation can help the engine warm up faster, acts as a fire suppressant if it falls down (on newer cars, not sure about these), and muffles engine noise.
On the other hand it also decreases engine cooling.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 11-07-2016, 09:28 PM   #9
LongBox
Some cars have insulation to absorb the noise. Maybe keeping the paint cool will help it look good for a longer period of time?
My stock 69 doesn't have any insulation under the hood. It's a base model.
I happen to like the sound of the engine, so I have no plans to put any sort of insulation under the hood.
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 11-07-2016, 10:03 PM   #10
cleszkie
cleszkie's Avatar
It looks custom when you raise the hood. I'll admit that I added insulation under mine, but its mostly to lower the heat on my fiberglass hood.
cleszkie is offline   Reply With Quote
Old 11-08-2016, 08:34 AM   #11
I see no point, other than protect fiberglass. The sun is the only heat that is hard on hood paint. never had a problem getting an engine to warm up on it's own. The heat comes from within that warms the mass. That's what a thermostat is for. The insulation would only hold heat in that had been created by the engine you wanted to warm up. The ambient temp is created by the object you want to warm up? The ambient temp is created by the warmed up engine. I don't see insulation making the engine too hot, though. The only issue I'd be concerned about is condensation created between hood and insulation being trapped
Old 11-08-2016, 09:15 AM   #12
Lou Boffa
Lou Boffa's Avatar
They look great.
Jim, that's good old LMC. Part # 38-7819 I believe. Its a good product and has held up well. I know LMC gets a bad rap sometimes, but this part has worked nicely.
Old 11-08-2016, 11:28 AM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Factory spec.
Yup... just the little rubber vibration isolators between the hood skin and the braces. No need for anything else.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-08-2016, 01:00 PM   #14
Jim70Chevy
Jim70Chevy's Avatar
Thanks Lou! It is now on the list to buy. Jim
