Old 03-29-2015, 09:33 AM   #1
solidaxel
solidaxel's Avatar
Cleaning Truck 5.3 Intake plenumn
What are you folks using to clean the inside of the truck intake?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 03-29-2015, 12:09 PM   #2
First c10
First c10's Avatar
Re: Cleaning Truck 5.3 Intake plenumn
Great thread as I was going to start one today. Can they be placed in a hot water parts washer? Or course with all the little parts and sensors removed.
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-29-2015, 01:28 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I used some shop towels and a tooth brush, dipping them in seafoam and a little scrubbing.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-29-2015, 04:31 PM   #4
First c10
First c10's Avatar
Will a hot water parts washer hurt it?
GO GO!!!
Old 03-29-2015, 05:42 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The manifold itself, probably not. Keep in mind its plastic, but stands up to engine temps regularly. Most parts washers are only "warm", so warping/distortion should be a concern.
That being said, the little seals, and sensors mounted on the manifold won't be as happy. I left all that stuff on mine when I cleaned it, aside from the seals which were being replaced.
Old 03-29-2015, 05:45 PM   #6
First c10
First c10's Avatar
Beside map sensor what else is there?
I have looked over it and can't seem to find anything that would hurt of it got wet.
GO GO!!!
Old 03-29-2015, 07:58 PM   #7
crazy longhorn
Fabricate till you "puke"
I cant see anything that you would hurt....I stripped 1 down like that & took it to the car wash. A little super soap ,inside & out, & a high pressure rinse... Nice & clean Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 03-29-2015, 09:21 PM   #8
H20cooled
Run it through the dish washer. :-)
H20cooled is offline   Reply With Quote
Old 03-30-2015, 09:06 AM   #9
solidaxel
solidaxel's Avatar
My only thoughts are what if you knock something loose and you put it back on the engine and it is sucked into the engine, will it burn it !!
LS 3 4L70E
Old 03-30-2015, 02:53 PM   #10
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I left all my DBW stuff on, so there's that. The EVAP technically, if you care about it.
Old 03-30-2015, 03:10 PM   #11
First c10
First c10's Avatar
Brew what about the EVAP? I am not sure I know what that is come to think of it...
GO GO!!!
Old 03-30-2015, 10:33 PM   #12
Willie Makeit
Willie Makeit's Avatar
Purple Power + hot water and a little scrubbing with a tooth brush will make it look brand new.
Willie Makeit is offline   Reply With Quote
Old 03-30-2015, 11:30 PM   #13
First c10
First c10's Avatar
I put it in a parts washer at about 180*. It cleaned up great just had to use a little carb cleaner and a towel and the runners cleaned up great.
GO GO!!!
Old 03-31-2015, 01:05 AM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Its the big thing that usually sticks out of the top of the manifold. Has a line running to it.
It actually doesn't matter if it works for most of us, but the emissions guys keep it.
Old 04-03-2015, 03:11 PM   #15
solidaxel
solidaxel's Avatar
Was the parts washer the same one the machine shop uses for cleaning engine blocks?
LS 3 4L70E
Old 04-03-2015, 03:18 PM   #16
First c10
First c10's Avatar
Not sure if it is a machine shop one but you could put an engine in it. We have it at my work. They can put just about anything in it.
GO GO!!!
Old 04-03-2015, 10:56 PM   #17
solidaxel
solidaxel's Avatar
My concern was the amount of heat it produces and warping of the composite intake
LS 3 4L70E
Old 04-04-2015, 02:26 PM   #18
First c10
First c10's Avatar
It's only 180*. The engine bay is way hotter I think.
GO GO!!!
Old 04-04-2015, 03:26 PM   #19
Andy4639
Old member
Andy4639's Avatar
Talking Re: Cleaning Truck 5.3 Intake plenumn
I sprayed mine in the drive way and soaked it good in Purple power then scrubbed and washed it again inside and out.
I've got another intake I plan to shave sometime and see if I can do it right.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-04-2015, 06:51 PM   #20
solidaxel
solidaxel's Avatar
180 * all day long!!
I will take it to the machine shop and let him have at it !
I will let you know what kind of job he did.
LS 3 4L70E
Old 04-09-2015, 06:42 PM   #21
aknovaman
Any trans shop has a heated washer that will work fine. I got one washed for $10 and it looked new when done. Takes less than 10 minutes.
Current project 1959 Willys = GEZR TRUK
Geezer is a Latin compound word made up of two roots.
Gee meaning Urine Stain and Zer meaning your pants are open!
FMCDH GBU and GBA
http://www.youtube.com/user/aknovaman/videos
aknovaman is offline   Reply With Quote
Old 04-10-2015, 08:52 AM   #22
solidaxel
solidaxel's Avatar
I took mine to the trans shop that does my work and asked him to put it in his "dish washer" and he said it would make the outside look great "but would not do much for the inside" !
I am going to the machine shop that I have some work done and get his opinion.
Was the carbon deposits cleaned from your runners?
LS 3 4L70E
Old 04-10-2015, 09:00 AM   #23
aknovaman
It should be clean in and out. Works very well at removing all the pcv injected sludge. You won't be sorry. Be sure to remove the o rings that mate to the head surface if you are doing a f body intake. The truck ones are part of the intake gaskets.
FMCDH GBU and GBA
Old 04-10-2015, 09:06 AM   #24
solidaxel
solidaxel's Avatar
................ Todays objective!
I will let you know what the machine shop does with it, Thanks
LS 3 4L70E
