03-29-2015, 03:45 PM | #1 |
Edelbrock Intake Bi Metallic Choke instillation ?
Anyone have experience hooking up the stock bi- metallic choke assembly on a Edelbrock intake ? When I went to hook it up to the choke lever on the QJet I found the push rod is way to long and out of position. Do you just cut and bend it to fit ? Thanks for any suggestions
71 C-20 07 Magnum RT AWD |
03-29-2015, 05:10 PM | #2 |
Re: Edelbrock Intake Bi Metallic Choke instillation ?
fully rotate the choke plate connector and take a picture showing how much of a gap you have.... Edit, never mind. Looked at mine old one iut in the garage and yours does look a fair bit longer
03-29-2015, 10:18 PM | #3 |
Just make a new one. Back in the day I used to experiment with different lengths to get just the right amount of choke. I used the correct thickness of brass gas welding rod.
71 Blazer 4X4 (unmolested, all original (including paint) 74,000 mile barn find) 67 Camaro RS SS (unmolested, all original (including paint) 81,000 mile barn find) Keith Riel |
03-29-2015, 11:27 PM | #4 | |
Edelbrock makes the right rod for the application. Scroll down and find the one for your part # intake. http://www.edelbrock.com/automotive/.../general.shtml |
03-29-2015, 11:37 PM | #5 | |
Keith
03-29-2015, 11:38 PM | #6 | |
03-29-2015, 11:48 PM | #7 |
03-30-2015, 10:19 AM | #8 |
Thanks for the tips
