Old 03-29-2015, 06:20 PM   #1
oldtrux
oldtrux's Avatar
stock oil pressure gauge question
anyone know what size and kind of thread on back of stock oil pressure gauge?i'm trying to get fittings to convert to -an fitting to use braided line instead of copper line.thx dan
oldtrux is offline   Reply With Quote
Old 03-29-2015, 06:41 PM   #2
davbowen
davbowen's Avatar
Re: stock oil pressure gauge question
1/8" npt with 1/8" compression fitting. i think you"ll need some sort of adapter.
davbowen is offline   Reply With Quote
Old 03-29-2015, 06:56 PM   #3
ray_mcavoy
The GM oil pressure gauges use a special type of compression fitting where the ferrule is built into the nut.
Weatherhead calls them "threaded sleeve" fittings and their 6100x2 nut will connect 1/8" tubing to the back of the stock gauge.
Edelmann calls them "double compression" fittings and their part number for the nut is 111200. The Everco equivalent is 11A.
I don't think anyone makes an adapter to go from the port on the stock gauge directly to AN.
ray_mcavoy is online now   Reply With Quote
Old 03-29-2015, 06:58 PM   #4
oldtrux
oldtrux's Avatar
great,thanks!sounds like i need 1/8''npt to -3-an adapter and i'm good.
Old 03-29-2015, 07:00 PM   #5
oldtrux
oldtrux's Avatar
posted same time as ray.so it's not 1/8'' npt??
Old 03-29-2015, 07:09 PM   #6
ray_mcavoy
1/8" NPT is pretty common on aftermarket gauges. And I have seen a few stock (mostly mid-70's medium duty truck) oil pressure gauges with NPT threads.
But the fitting I posted above is what I've seen on the vast majority of GM oil pressure gauges. If I remember correctly, they have straight 5/16"-24 threads (like a bolt). The seal is formed by the special tapered end of the nut which acts like a built-in compression ferrule when it's tightened down into the port on the back of the gauge.
Old 03-29-2015, 07:33 PM   #7
oldtrux
oldtrux's Avatar
ok thanks ray.so i guess there would not be a fitting to convert to even npt.hhhmmm??
Old 03-29-2015, 07:55 PM   #8
ray_mcavoy
If such a fitting exists, I'm not aware of one.
Weatherhead, Edelmann, etc. all make connectors that adapt NPT to the "threaded sleeve" / "double compression" type connection used on the gauge. But they're the opposite of what you need. They have a female port (just like the back of the gauge) and male NPT threads.
Old 03-30-2015, 09:13 AM   #9
1963c-10
1963c-10's Avatar
I have all the part #'s to convert to a -an braided line, give me a few minutes to get them out of my build thread.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-30-2015, 09:15 AM   #10
1963c-10
1963c-10's Avatar
Ordered the stainless oil pressure gauge / block kit through Summit. Its an Auto Meter kit #3235. This kit is a 4' length, but they have a longer one also.
The hose is -3 AN which is 1/8" inside, so same as the plastic line kits, but looks much better.
Old 03-30-2015, 09:18 AM   #11
1963c-10
1963c-10's Avatar
Couple more pics and the fitting for the back of the gauge
Old 03-30-2015, 01:37 PM   #12
oldtrux
oldtrux's Avatar
Thanks very much for the info 1963c10!i will order that up today!
Old 03-30-2015, 03:28 PM   #13
1963c-10
1963c-10's Avatar
No problem. I keep all my part numbers just for these reasons.
Old 03-30-2015, 03:48 PM   #14
MikeN
MikeN's Avatar
Both ends of the hose are female. I see the fitting in the photo that inserts to the back of the gauge, but I don't see another fitting in the photo to screw into the engine block that also has a male end to connect to the hose?
MikeN is offline   Reply With Quote
Old 03-30-2015, 04:14 PM   #15
1963c-10
1963c-10's Avatar
Post 11, 1st pic...it has the plastic cap on it to protect the threads.
Also pictured in the kit on post 10.
Old 03-31-2015, 08:41 AM   #16
1963c-10
1963c-10's Avatar
Thought about this last night and your correct. Not in the pics....but already installed on the my engine is a 5/8" adapter to connect to the line kit fittings (at least on the big blocks, I imagine the small blocks are the same). On the big blocks, the port is centered over top of the oil filter. I can get pics tonight if needed. The oil pressure switch which I'm not using that normally screws in the block is a 5/8" thread fitting. Easily found part at most auto parts stores.
Few pics of the install I did. PO had an existing hole drilled here, so I used that hole, but it widens to 3/4" for the grommet and stainless line to pass through.
The kit says to slit the grommet, but I didn't have any issues getting it over the fittings...just take your time and it'll work on.
Old 03-31-2015, 12:16 PM   #17
MikeN
MikeN's Avatar
Cool, thanks!
Old 05-31-2015, 01:36 AM   #18
Crazy Rusty
Crazy Rusty's Avatar
Just to confirm, the auto meter kit didn't come with the fitting to connect to the pressure gauge, you got a 5/16-24 x 3AN fitting separately correct?
Is this the correct one?
Edelbrock 76525 Flare Fitting Adapter, Straight, -3AN x 5/16-24 Stainless
Crazy Rusty is offline   Reply With Quote
Old 06-01-2015, 08:05 AM   #19
1963c-10
1963c-10's Avatar
That's correct. The fitting to the gauge was not included in the kit.
Old 06-03-2015, 02:33 PM   #20
1963c-10
1963c-10's Avatar
Summit racing #16150 was the fitting I used.
Heres the link: http://www.summitracing.com/parts/nex-16150
Old 06-03-2015, 03:28 PM   #21
Crazy Rusty
Thanks, should be picking up one today so I can finally have a working oil gauge
