03-29-2015, 08:21 PM | #1 |
Help identifying year of this crossmember
Did some garage cleaning today and I have no idea where I got this front crossmember. I am debating keeping it or not. Can anyone identify if this is a newer style 73-87 crossmember?
Thanks. Jake
63 1ton Paneltruck build: http://67-72chevytrucks.com/vboard/s...d.php?t=627721 Instagram: jaked937 |
03-29-2015, 08:22 PM | #2 |
Re: Help identifying year of this crossmember
Sorry, can only upload 1 pic at a time from my phone.
03-29-2015, 08:24 PM | #3 |
And last shot
03-29-2015, 09:38 PM | #4 |
Solid control arm bushings and coil springs mean it's a '63-'72
03-29-2015, 09:58 PM | #5 |
03-29-2015, 10:12 PM | #6 |
67-72 parts collector,…
Brake line connection on the FRONT side of the a-arms means it's a 71-72 crossmember.
03-30-2015, 12:19 AM | #7 |
60-66 Nut
It could also be a C20/30 crossmember from '71-'87. The C20 and 30's retained the steel control arm bushings. But with the brake line connection right on the crossmember like that I would agree with a '71-'72 C10,20 or 30
03-30-2015, 08:11 AM | #8 |
So I probably should just get rid of it. I was debating keeping it in case I want to build another c10 one day but if it's an older crossmember I might as well pitch it.
03-30-2015, 12:47 PM | #9 |
There is nothing wrong with the older crossmembers. You can bolt up later control arms to it or if it is a early 3/4 ton the lower control arms will not be bolted on with U bolts. Hard to tell if there are u bolts there with all that mud and greese build up..
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
