New Voltage Regulator - Lost headinghts
Went to the Spring Turkey Rod Run this weekend. Stopped for gas before we entered the show and checked under the hood and noticed the battery was boiling over. So yesterday I installed a new voltage regulator. So far the battery isn't boiling over but I have lost my headlights. Any thoughts of why I lost my headlights? All other lights are working properly. Thanks' in advance for your input.
Re: New Voltage Regulator - Lost headinghts
Blown fuse ??
If you don't like this ![]() |
Fuses are all good
Never Ending Projects
Besides the wiring, it could be headlight switch, dimmer switch or the bulbs burnt out. Test light will go a long way to troubleshooting.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
1962 C-10
Didi you check the plug for the headlights on the radiator support? Maybe it was knocked loose somehow.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
My truck was overcharging and someone here suggested to check the ground between the regulator and alternator. That tip helped me out. Measure across the battery terminals, it shouldn't be more than about 14 1/2 volts.
Could be a coincidence.....I would turn the headlights on and click the dimmer switch and see if the brights come on. Typically when both go headlights go out, it has to do with the dimmer switch dying out. (Had that happen in my 56 Chevy one night...scary when the lights all go out at once when you're flying down the road!
![]() But yeah, if the fuse is good, I'd check the dimmer switch next.
1965 C10 LWB SBW, 292, SM420 1963 Chevy II SS 1951 Chevy Business Coupe Gasser 1949 Willys Overland |
