03-30-2015, 10:58 AM | #1 |
A/C Vents
I'm about to change out the a/c vents on the passenger side. They will not stay in place and I was wondering what y'all were using to seal around them and help hold them in place.
Tommy 1 Pt. 3:21 '72 C10 LWB 402 |
03-30-2015, 11:17 AM | #2 |
Re: A/C Vents
Black velcro cut to size or rubber o-rings on each end/side can help tighten things up.
03-30-2015, 11:32 AM | #3 |
Re: A/C Vents
03-30-2015, 07:32 PM | #4 |
Re: A/C Vents
I got the wrong vents grrrrrrrr. Did I order for the wrong year?
04-01-2015, 06:25 PM | #5 |
Re: A/C Vents
The driver side 'center' vent is the one w/the larger center pin. The Pass side 'center' & vent near the door both have the smaller center pin. All 3 of those vents are the same approx size/length.
