283 top radiator pipe
After searching, I did not find any info for the dimensions and angles to bend the pipe. Anyone have them?
This is what I'm looking for.
Father and son built. Driven daily since 2012. 283, 3 speed. Mostly original. '81 PS and disk front. Fuel tank relocate. Maintenance, repairs and upgrades on his dime now. http://zacks64longfleet.shutterfly.com/ Higher res. photos in my gallery. |
Re: 283 top radiator pipe
I have an extra one I won't be using. PM sent
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
![]() Join Date: Feb 2015
I like that solid style
![]() Join Date: Aug 2013
Pic for ljackson. Its the bottom one in the pic
Photo credit to Newfisher
I'll take it. you said $30.00 shipped correct?
I do have a source for stainless tubing. I may make some if anyone is interested.
Yes, but we need to PM. Cant do transactions on the threads. Classifieds or PM or they'll lock it.
PM sent
It's Better With Nitro
I make mine from leftover exhaust tubing scrap. I also did the bottom tube and had them ceramic coated along with my zoomies a few years ago...
Nice.....really liking the bottom hard pipe. Would like to make one for my big block build
what diameter are these hard pipes?
what the cost of the stainless?
MY 65 C20 BUILD http://67-72chevytrucks.com/vboard/s...d.php?t=483346 ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
[QUOTE=vin63;7113729]I make mine from leftover exhaust tubing scrap. I also did the bottom tube and had them ceramic coated along with my zoomies a few years ago...
[URL=http://s268.photobucket.com/user/vin63/media/Products/Ceramic%20Coating_zps0vmu9fsi.jpg.html] ![]() |
#13 |
#14 |
The pipe I bought from 1963c-10 isn't going to work. It may have been bent for a newer truck. Maybe early 70's with a 350? It is 1.5" on each end. The 283 is 1.75". What are your thoughts?
#15 |
can you use the rubber sections at each end to give a little play during instal?
#16 |
I don't know. I may give it a try.
#17 |
#18 |
believe that there is a guy in Kansas that has them, but he may have problems shipping them
ron |
#19 |
1961 crewcab
I believe it might fit once you get the old hose off and are able to line it up better...
when I put the Pontiac 455 in my 63 I just used a piece of baling wire to get the shape, and then had an exhaust shop bend a tube for me. like the way yours is pictured, at first I did not think it would fit, but after I put the rubber hoses on the ends it fit into place.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
#20 | |
#21 |
All I have is this picture.
#22 |
Comparing the 2 pictures in post 14 and 21.
Post 14 has the short bend on engine side and 21 has short bend on the rad end. Try turning it the oppisite way. Sometimes it is a simple fix. |
#23 |
![]() Join Date: Feb 2014
I can make one. I need a template (either 1.5 or 1.75 template). aluminzed steel or 304SS, hose beads, mandrel bends. One off custom will not be in-expensive. I agree with flipping end for end and trying that. Bruce
