Old 08-28-2003, 06:34 PM   #1
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
Question Need Help Deciding on Front End
Well I fell into a few extra bucks and decided to get to work on something on the truck. The thing that drives me nuts right now is the front end. I need to get it aligned but no sense in doing it without getting the whole front end done. 24+ years are showing their age and need to get it fixed. Now here's my options on manufacturers and packages they have for my truck unless someone happens to know a better setup.
Energy Suspensions $183.95
Material- Polyurethane
* Front control arm bushings
* Rear spring and shackle bushings
* Front sway bar bushings
* Body mounts
* Tie rod end boots
* Transmission mount
P-S-T $219
Material- Polygraphite
* 2 Upper Ball Joints
* 2 Lower Ball Joints
* 2 Outer Tie Rod Ends
* 4 Upper Inner Bushings
* 2 or 4 Lower Inner Bushings (as required)
* 2 Strut Rod Bushings (as required)
* 2 Stabilizer Links*
* 2 Sway Bar Bushings**
* Control Arm Bumpers (most models)
Performance Suspension Components $279.95
Material-Graphite Impregnated Polyurethane
* Upper & Lower Ball Joints
* Inner & Outer Tie Rod Ends
* Idler Arm
* Complete Upper & Lower Shaft Assemblies (Where Applicable)
* Graphite Impregnated Polyurethane Bushings*
* Upper & Lower Control Arm Bushings
* Sway Bar Bushing Kit with Brackets
* Polyurethane Tie Rod Boots
What's the best deal? I remeber that the graphite impregnated are better at not squeaking which makes me lean towards them. Now if it's betwwen P-S-T and Performance Suspension is the extra $$$ worth what extra you get or can I get the parts cheaper buying them elsewhere? Also does anyone know if I can buy Peformance Suspension Componets from another place like Summit?
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 08-28-2003, 11:54 PM   #2
BigRed
I've heard very good things about Energy Suspension. Although, that PST kit comes with alot! Hopefully somebody with a little more knowledge will chime in.
Scott Shelbourne
BigRed is offline   Reply With Quote
Old 08-29-2003, 12:00 AM   #3
BaggedC10
Under construction!
BaggedC10's Avatar
P-S-T all the way! Awesome service and they're products are top notch.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 08-29-2003, 12:42 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
What ever you do, DO NOT use anyone that offers polyurathane "only" bushings. Sooner or later they will squeak like mad. The money saved is not worth your sanity.
PST and PSC appear to have the same parts in their kit. They both use polygraphite bushings, so they won't squeak. It looks like the PST kit is just cheaper, but make sure there isn't some difference. If not, I think you have a winner with PST....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 08-29-2003, 12:44 AM   #5
Izzy
Trucker.
Izzy's Avatar
I agree. The only noticable difference is the PSC kit has inner tie rod ends and the idler arm.
Izzy is offline   Reply With Quote
Old 08-29-2003, 01:06 AM   #6
bigblock73
yeller
bigblock73's Avatar
I can only give props to PST, I used the same kit on Yeller and loved the difference it made. The truck cornered very well and that was with NO swaybars. Also, the $219 price INCLUDES shipping!
-Jeff
bigblock73 is offline   Reply With Quote
Old 08-29-2003, 01:24 AM   #7
Nvbowtie
Nvbowtie's Avatar
P-S-T
www.unlimited2u.com/chevy
1980 Chevy C-10 Silverado
1988 Chevy Blazer Tahoe
Nvbowtie is offline   Reply With Quote
Old 08-29-2003, 05:20 AM   #8
TIMSPEED
TIMSPEED's Avatar
Here's another vote for PST. It made a TREMENDOUS difference in cornering on my truck...but on the same token it made the truck VERY stiff...but I guess that's my fault, cuz the truck is so damn light.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 08-29-2003, 11:14 AM   #9
low 84
low 84's Avatar
this is why i got the PSC kit. it comes with everything. i don't know why they leave the inner tie rods and the idler arm out of the PST kit. you will definatly want both of those to do the front end rebuild. they are worn out for sure after 25 years. i had a bad idler arm on mine and it was causing crazy front end problems. i bought another idler arm one time at orielys by itself and i think it was close to 40 bucks just for the house brand one. so if yu get the PST kit and then go by an idler arm you'll alredy be close to 260 and the inners tie rods and you'll be over what you would have spent on the PSC kit. that was my reasoning behind getting the PSC even though it costs more
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 08-29-2003, 12:31 PM   #10
Jonboy
Slots go on anything!
I used the PSC stuff on my 92 Z28. It was quality stuff, and did not squeak. The customer service was good, too. You can also buy sway bars and springs from them as well.
1974 Jimmy- 5.3/4L80e/NP241
Old 08-31-2003, 02:40 AM   #11
79BIG10
79BIG10's Avatar
Sounds like the PSC would be the sure way to go. Plus that price is with shipping as well. I'll get the check next week so as soon as it hits I'll be ordering something then along with front springs
Old 08-31-2003, 03:23 AM   #12
jimfulco
Somebody makes greasable polyurethane bushings, but I can't remember who.
jimfulco is offline   Reply With Quote
