Old 03-30-2015, 06:55 PM   #1
Matador
Torque Converter Issues?
I just bought a 2000 K3500 Crew Cab/Long bed. I put it in here, because it's a GMT 400 truck. If it belongs in the 99+ section, please feel free to move it.
Anyways, the truck had rod knock, so I had the guy I bought it from put in a new Goodwrench 350. The transmission is the automatic, and it has the floor-shifting 4x4. The truck drives nicely, but it has an odd shifting problem:
You're driving along normally, doing 65 at about 2200RPM. The torque converter locks up as you climb a hill, and the RPMs rise to 3000. So far, so good. The problem is that the torque converter never unlocks. You'll stay there until you stop the truck and shut it off for a minute.
I have it going into the shop on Thursday, but didn't know if you had any idea. The mechanic (different guy than I bought the truck from) knows a lot about these trucks, but has never heard of this happening.
Any ideas?
Matador is offline   Reply With Quote
Old 03-30-2015, 08:14 PM   #2
Tom
driving is in my blood
Tom's Avatar
Re: Torque Converter Issues?
Im confused, you mean the convertor UNlocks and the rpm's rise, and after that point it never locks back up? If so then it sounds like a servo or the torque convertor itself going bad. I had the lockup clutch in my 200mile old built 200-4R go bad on me once. If instead you mean the convertor locks and thats when the rpm's rise, then sir you are properly screwed as thats not how it supposed to work lol.
Old 03-30-2015, 08:42 PM   #3
Matador
My terminology isn't the best.
The truck will drive down the road normally at 65 at 2200 RPM, like it should. Then, as soon as I get to a hill, the torque converter does something (Unlocking- my phrasing was backwards), and the RPMs increase to 3000-3100 (Same RPM as if I shift into third). Then, it stays there until I stop and turn off the truck. If I go down a hill with cruise control on, the RPMs will fall to 1000 (Idle), and will pick right back up at 3000 at the bottom of the hill.
I'm basically driving in third gear and not overdrive after I encounter a hill.
Old 03-30-2015, 09:49 PM   #4
HeavyChevy81
Doesnt sound like a Converter problem to me. I'm thinking more along a transmission sprag not holding.
Normal lockup decreases revs approx 150-200.
the increase you are seeing is more like downshifting a gear, therefore a possible sprag.
Could also be a solenoid issue, not allowing upshift at high pump pressures.
Will it upshift if you manually pull down to direct, then manually go to OD?
Just my 2 cents.
Lane
HeavyChevy81 is offline   Reply With Quote
Old 03-30-2015, 09:59 PM   #5
Matador
Moving the lever from Overdrive to 3rd on the column doesn't change the RPMs at all. If I go back to OD from 3rd, the RPMs stay the same (As they are in 3rd gear). So, I'm basically in 3rd then, right?
If it's a sprag or solenoid, what does that mean I'm in for?
Old 03-30-2015, 10:09 PM   #6
HeavyChevy81
Trans is probably a 4L80E, I'm assuming.
OD is an additional reverse rotation sprag added to the extreme rear of case.
The sprag is simply a mechanical one-way clutch to hold when a planetary unit is engaged for gear reduction.
This being said, if sprag is bad, or planetary failure, means the tranny is coming out to be rebuilt. Automatic tranny failures usually require a complete rebuild for cleanup of debris. I would continue testing, every piece of info you can give to you mechanic of choice is valuble in determining course of action.
Hate to sound so negative, but prepare for the worst, hope for the best.
Again, just my 2 cents.
Lane.
Old 03-30-2015, 10:14 PM   #7
HeavyChevy81
also, you stated going downhill rpms's drop to approx 1000. This is another indication of a sprag not holding. (no engine braking).
Old 03-30-2015, 11:08 PM   #8
Matador
Yeah- the engine is idling when I go down a hill. It's the 4L80E. Is there anything I need to be aware of? I don't want to make matters worse.
If it's overdrive causing the issue, would it be best to use 3rd gear when taking the truck in for repairs?
It sounds like I may be getting a second transmission swap done in 12 months! I was trying to avoid this!
Old 03-30-2015, 11:12 PM   #9
HeavyChevy81
Honestly, damage already done.
Just get to repair shop as easily as possible.
Lane
Old 04-12-2015, 06:47 PM   #10
Matador
Sadly, everyone was right. The transmission was slipping big time.
We're having a reman one put in. Any tips to make it last the longest?
So, the man we bought the truck from put a new engine in there for us and drove it around. I'm assuming that he would have known about these issues, right?
At least we'll have everything replaced and in good order when it's finally usable!
