Old 03-30-2015, 07:48 PM   #1
pimpston65
pimpston65's Avatar
need some gear help
i posted in the 4x4 section, just wanna cover my bases. can anyone show me an exploded view of how these go together and why the are different. also does it matter which side they go on?
pimpston65 is offline   Reply With Quote
Old 03-30-2015, 07:50 PM   #2
pimpston65
pimpston65's Avatar
Re: need some gear help
the sharpie is pointing at the used gear and the other is my NOS gear.
Old 03-30-2015, 09:27 PM   #3
LT1 Burb
LT1 Burb's Avatar
I don't know anything about them but looking at them I would say it doesn't matter which side it goes on.
LT1 Burb is offline   Reply With Quote
Old 03-30-2015, 09:38 PM   #4
pimpston65
pimpston65's Avatar
thats what i say, but one has a groove machined into it near the teeth and the other doesnt, just wanted to know if there needs to be a snap ring. i found an exploded view in a GMC master parts book. i have a library around the corner with a hugh automotive section maybe i can find it there. this will be my road trip rig cant have it jacking up offroad climbing pikes peak!!! thanks for the reply gave me a needed BUMP...
Old 03-31-2015, 09:45 AM   #5
LT1 Burb
LT1 Burb's Avatar
I wonder if it was a superseded part, originally made w/o a snap ring and they realized they needed one.
Old 03-31-2015, 10:06 AM   #6
pimpston65
pimpston65's Avatar
thats too funny, i was thinking they just had a bunch of usable parts and figured it didnt matter and just tossed them together cuz the worked with or without the snap ring. as long as there is an internal groove for a snap ring to hold the inner gear it won't matter, also if one groove is closer to the outer hub then it will be side orientated, or there may be 2 grooves on the shaft for either of the inner gears. i need pictures of live setups, cuz i only have the hubs off the burban. i will be able to check in a week as thats the next time i will be at my storage unit... thanks for your help!!! hey i have a few parts i will be posting also in a week!!! PM sent
Old 03-31-2015, 10:39 AM   #7
60-66
60-66's Avatar
Whats the part number on your gear Winston ?
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-31-2015, 10:58 AM   #8
pimpston65
pimpston65's Avatar
GR.6.308 3867378 is the hub,3958029 this is the taller one,3937071 is the one with the groove
Old 03-31-2015, 11:35 AM   #9
60-66
60-66's Avatar
Hmm , parts book shows 3781982 as the hub ,3867378 as the gear 1960-1968, 3958029 as the ring with bushing 1970-1974 K20 and 3937071 as the Bolt for 1968-1980.
Old 03-31-2015, 12:18 PM   #10
61K10
61K10's Avatar
I would try to fit everything in each hub. As long as you can get the axle c-clip on and the outer fits the splines, and snap ring goes in, you should be good to go.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-31-2015, 01:52 PM   #11
pimpston65
pimpston65's Avatar
thank you everyone, i will attempt to dry fit one hub this weekend and report back!!!
