Old 03-30-2015, 10:40 PM   #1
sodly
sodly's Avatar
1966 GMC with TH400 auto
I believe you could order the TH400 auto transmission behind a big GMC v6 in 1966 only. I don't think I've ever seen this combo in a real truck. Does anyone have one? Or photos? Just curious about its popularity. Wonder how well suited the two were to one another. Anyone have experience with it?
WANTED:
* 60-66 Chevy and GMC FACTORY PHOTOGRAPHY (scans) of pickups and carryalls.
Custom Camper Club-- Own a 65-66 Custom Camper? Join us at: http://67-72chevytrucks.com/vboard/g...hp?groupid=117
sodly is offline   Reply With Quote
Old 03-31-2015, 08:50 AM   #2
1963c-10
1963c-10's Avatar
Re: 1966 GMC with TH400 auto
Was one that popped up on her last year. I believe it was up in Nebraska....had the TH400 and it was a 66. What brought all the attention was the factory 3 speed auto column.
Found the link: http://67-72chevytrucks.com/vboard/s...d.php?t=577214
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-31-2015, 02:07 PM   #3
Figuarus
Figuarus's Avatar
Ive got a 283 with a TH400 out of a 71 Monte Carlo. It's a custom job, but it's possible.
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 03-31-2015, 09:19 PM   #4
sodly
sodly's Avatar
No, I'm looking for a V6 GMC backed with a TH400 from the GMC factory.
WANTED:
Old 04-01-2015, 06:19 PM   #5
Classic v6 GMC's
Classic v6 GMC's's Avatar
This one on ebay has a 305 v6 and th400. Not mine
http://www.ebay.com/itm/GMC-Other-fl...m=301577495632
Classic v6 GMC's is offline   Reply With Quote
Old 04-01-2015, 10:52 PM   #6
sodly
sodly's Avatar
From what I can see of the column it looks like it might be a 3 speed auto. Description doesn't specify.
WANTED:
Old 04-02-2015, 09:31 AM   #7
Classic v6 GMC's
It does not specify but under the hood if you look real close you can see a kickdown switch.
Old 04-03-2015, 08:01 PM   #8
factorystock
factorystock's Avatar
It appears the TH 400 was a 3/4 ton only thing ( GMC 1500=Chevy 20) in 1966, and it was available with all engines. A $242 option back in '66, wow, what is that in today's dollars?
factorystock is offline   Reply With Quote
Old 04-03-2015, 08:31 PM   #9
jdl71
jdl71's Avatar
$1753.71
http://data.bls.gov/cgi-bin/cpicalc....966&year2=2015
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 04-04-2015, 10:04 PM   #10
sodly
sodly's Avatar
Anybody own one? Seen one?
WANTED:
Old 11-07-2015, 12:17 PM   #11
factorystock
This one still makes me cry. A truck you don't find everyday. Highly optioned low mileage original paint 3/4 ton survivor truck gets the knife and repaint. Here's the write up towards bottom of page. http://www.oldchevytrucks.com/blog/i...eaturedtrucks/
Old 11-07-2015, 02:53 PM   #12
60-66
60-66's Avatar
Wow ! What a shame. Sure would've liked to see that build sheet.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 11-07-2015, 11:57 PM   #13
sodly
sodly's Avatar
Back when most folks didn't know any better. Another one bites the dust.
WANTED:
Old 11-08-2015, 01:43 AM   #14
Captainfab
60-66 Nut
This past summer I had the opportunity to buy a '66 GMC 3/4 ton that was equipped with the original TH400, Dana 60 differential. The V6 had been replaced with a 305 SBC. This truck also did not have the vulcanized rubber rear cab mounts. It had what you would typically find on a 1/2 ton. I had to pass on the truck and it was sold to a guy from Colville Washington.
Old 11-08-2015, 12:13 PM   #15
TJ's Chevy
TJ's Chevy's Avatar
I know Ed though, and he is one of the nicest and most knowledgeable guys you'll meet. At the time he probably just didn't know what he had. But in my opinion...he did a nice restoration. He coulda done worse and thrown a 350 in there and slammed the thing. I like that link though....I got stuck on a couple Chevys posted there! lol
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 11-08-2015, 03:59 PM   #16
jdl71
jdl71's Avatar
That '62 4x4 (the first one on the list) is just pure awesomeness.
Psalm 23
64 C10
66 K20
Old 11-08-2015, 11:23 PM   #17
TJ's Chevy
TJ's Chevy's Avatar
I sat and looked at that one for some time. lol
Old 11-13-2022, 11:58 PM   #18
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Wondering What Bell Housing Looks like
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 11-15-2022, 02:07 AM   #19
Bob B.
For an automatic behind a GMC V-6? Actually they used a Chevy pattern Powerglide or Turbo 400, there was a 2 peice adapter that mated to the V-6 block and had the Chevy bellhousing bolt pattern on the back side. It was used with an iron flywheel and a separate flexplate. The flywheel had an extended hub that brought the flexplate back to meet the torque converter. Good thing about those adapters is that they allow you to use a 700R4/4L60 or 4L80 behind a V-6 if you want to.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 11-15-2022, 02:59 PM   #20
MusicMan70
MusicMan70's Avatar
Here's a photo and the support rods for the Turbo 400
MusicMan70
1961 GMC Suburban
MusicMan70 is offline   Reply With Quote
Old 11-15-2022, 07:57 PM   #21
Bob B.
Were the support rods used on the '67 and '68 trucks? I don't remember seeing them.
Old 11-16-2022, 11:24 AM   #22
MusicMan70
MusicMan70's Avatar
This thread from the 6066 site seems to imply that they did, but were recalled{?}
https://6066gmcclub.com/showthread.p...t=support+rods
MusicMan70
1961 GMC Suburban
Old 11-18-2022, 02:05 AM   #23
Bob B.
Interesting, sounds like the rods were a 'fix'. Possible there was a bulletin instructing dealers to install the rods if customers complained. That could explain why they are not on every truck.
Old 11-19-2022, 10:02 PM   #24
72highlander
Sophomore Member
72highlander's Avatar
I have this 66 3/4 ton. 351, auto, custom cab, big glass, power steering and power brakes. It’s not a runner. I was going to steal the auto out of it for another truck but can’t make myself take it apart. Rare bird.
1972 Chevrolet Highlander SWB
1972 Custom Deluxe 3/4 2WD 60k miles
these trucks don't need vacuum gauges cause they don't suck!
two wrongs don't make a right, but three rights do make a left
all i want is a little more than i'll ever get
it's better to be judged by 12 than to be carried by 6
72highlander is offline   Reply With Quote
Old 11-20-2022, 02:34 AM   #25
1971 GMC SHORTY
Anyone Have These Laying Around Collecting dust they’d like to part with the
2002 FXDP
