Old 03-31-2015, 09:08 AM   #1
Nacho_Paras N.L.
1966 C-10 Stepside Build/Upgrades
Hey guys, I'm fairly new to the site, but I'm here to share my changes to my Orange Beast Hot Rod... I had it as a street/strip truck... More on the track than the street. It has a 468 BB, 400 turbo trans, semi-automatic with a 3500 stall, reverse pattern shift and transbrake. I upgraded the front with CPP disc brake conversion kit which up graded all the ball joints to 73-87 type ball joints and 2.5 drop spindles with a 5 on 5 bolt pattern. In the back, I narrowed the rearend 5" over all to tuck in the 15x10 centerlines with a 5" back spacing. I also put moser axles 5 on 5 pattern with a 4.10 gear and a spool. Ilowered the rear with CPP 4" drop springs and 1.5" drop blocks.
My goal now is to put it on the street 100%. So, I will be adding some new wheels, Intro Rally 20" x 12" with an 8" lip in the rear and 20" x 8.5" in the front. Lowering the truck another inch or so all the way around, depending on the stance after the new wheels are mounted. Adding a C- notch to the frame. Changing Fuel cells for more fuel capacity. Higher gear ratio for the rear end to a 3.73 posi. and etc....... All the little things tha my come. Which I'm sure they will.. Add a bench seat instead of the racing seats that I currently have in it. Put in a new wood bed kit because I currently have a sheet of plywood in it.. And much more with time... Somewhat show quality but driven every weekend..
Nacho_Paras N.L. is offline   Reply With Quote
Old 03-31-2015, 09:20 AM   #2
1963c-10
1963c-10's Avatar
Re: 1966 C-10 Stepside Build/Upgrades
Nice, would love to see some pics of the drivetrain. Just got done doing a big block conversion in my 63!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 03-31-2015, 12:10 PM   #3
Nacho_Paras N.L.
Thanks, I'll take a couple of pictures of the engine this evening... I've never been to fond to show my engine compartment since no work was ever done to make it nice. Although the motor was built strong, the outside was not built for presentation if you no what I mean. If I recall correctly, we made room to fit the Big Block by hammering the fire a bit... So you can already imagine what it might look like.
All that will be different now. I'm hoping to redo the firewall and push it back and make room the right way.
Old 03-31-2015, 03:55 PM   #4
Justin@EntropyRad
Justin@EntropyRad's Avatar
Not normally a fan of red and scoops..but that thing look right!
* Call me NOT the website number*
Justin Novick
(773) 303-8251
Sales/Support
Entropy Radiator / Engineered Cooling Products
"The Sexiest Radiators For The Sexiest Hot Rods" - www.EntropyRad.com www.speedcooling.com
Justin@EntropyRad is offline   Reply With Quote
Old 04-01-2015, 08:47 AM   #5
Nacho_Paras N.L.
Thanks Justin... I appriciate it.....
Old 04-01-2015, 08:50 AM   #6
1963c-10
1963c-10's Avatar
Yeah, I had some fitment issues too, but mine was frame trimming for the mounts and headers. My firewall clearance was good. Heres a pic of my progress to date. I'm so ready to fire this old beast up.
I also went to a hydraulic clutch as I really like a manual trans, but surprisingly those issues were resolved fairly easy.
Keep up the progress and lots more pics!!
Old 04-01-2015, 08:51 AM   #7
Nacho_Paras N.L.
So I ordered the Intro Rally Wheels in January and I finally got them in Yesterday. Here's a couple of pictures of the rear rims.. 20" x 12" with an 8" lip.. I should be getting the tires in Friday... I went with 29" x 15" R20 Mickey Thompson Sportsman for the rear and 255/35 R20 Mickey Thompson Street Comp in the front.
Old 04-01-2015, 09:00 AM   #8
Nacho_Paras N.L.
That looks really nice.. Clean set up.... What headers did you go with?
Old 04-01-2015, 09:17 AM   #9
dwcardfan
dwcardfan's Avatar
Very nice. Love the wheels.
dwcardfan is offline   Reply With Quote
Old 04-01-2015, 09:22 AM   #10
1963c-10
1963c-10's Avatar
Hedman HTC 69136
http://www.hedman.com/site/?d=118&dt...keID=&ModelID=
Old 04-02-2015, 07:55 AM   #11
Nacho_Paras N.L.
I couldn't help myself yesterday, I had to see at least one rim mounted... Tracking says tires are out for delivery!!
Old 04-02-2015, 10:31 AM   #12
TJ's Chevy
TJ's Chevy's Avatar
Good looking set of rims.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 04-03-2015, 08:22 AM   #13
Nacho_Paras N.L.
Got my tires in yesterday evening.... I hope to get them mounted tomorrow morning... First thing my son did..... Got in the tire... I think that's all I'll have time for... Got to work on the "honey do list" this weekend.. I Have a baby on the way and the wife wants the babies room painted and the guest room painted. No complaints here since I see more $$$ going to the truck...lol
Old 04-03-2015, 01:19 PM   #14
dwcardfan
dwcardfan's Avatar
Priceless!!!!!!
Old 04-07-2015, 06:30 AM   #15
Nacho_Paras N.L.
I was able to get the tires mounted this weekend......
Old 04-07-2015, 06:36 AM   #16
Nacho_Paras N.L.
And I was to scratch off some items on the list from the wife... Bedroom painted and crib assembled. What is it with the chevron pattern these days. It was a headache to outline and tape... Guest room also painted... Busy weekend...
Old 04-14-2015, 07:10 AM   #17
Nacho_Paras N.L.
I was able to find some time and went ahead a put the front wheel on. I jacked the rear up and put the truck on some jackstands to test fit the the rear wheels to see how much I would need to narrow.
Then, I took off the rear end and took it to Pyle Bros. out in Baytown, TX. Having to narrow it 2.750" off of each side leaving it 53.500" on over all legnth. Going with a 3.73 gear positrack. Since I had already got it narrowed ons before, I already had moser axles in it, so they'ss just send my axles and get them resplined. Save a little bit of $$ there..
Old 04-14-2015, 08:11 AM   #18
Nacho_Paras N.L.
I went ahead and ordered CPP c-notch kit, CPP rear shock relocator, CPP 5" drop Springs for the rear and 3" drop springs with CPP 3" drop shocks for the front.
I ordered new bushings for the trailing arms and trac bar from Energy Suspension.
I should be getting everything in by the end of the week..... Hopefully...
Pyle Bros. told me they'll be taking about 2 weeks for the rearend, so that will give me some time to work on the suspesion while I wait...
Old 04-18-2015, 05:45 AM   #19
Nacho_Paras N.L.
Got some items in yesterday.... Time to get to work...
Old 04-18-2015, 02:23 PM   #20
68Gold/white
Great work!!!
Your son looks a little tired...
68Gold/white is offline   Reply With Quote
Old 04-18-2015, 08:09 PM   #21
chad64chevy
chad64chevy's Avatar
wow, what a great start to a thread! I like those 20x12
chad64chevy is offline   Reply With Quote
Old 04-20-2015, 07:45 AM   #22
Nacho_Paras N.L.
Thank you!!
Old 04-20-2015, 07:51 AM   #23
Nacho_Paras N.L.
I was able to get a lot done over the weekend... Got the notches in place and painted and put the new bushings in the trac bar and trailing arms.
Old 04-20-2015, 07:55 AM   #24
Nacho_Paras N.L.
I also got the shock reloacaters and 5" drop springs on.... Now I just wait for a phone call for the rearend... Hopefully it will be sometime this week....
Old 04-27-2015, 08:22 AM   #25
Nacho_Paras N.L.
Got the rearend back Thursday from Pyle Bros... I went ahead and did some touch up paint on it Friday...
