Old 03-31-2015, 01:17 PM   #1
Steve Cole
Anyone successfully rebuilt their hood hinges?
I don't mean send them out and pay someone else to do it, I mean drill out the rivets, oversize the holes and install larger rives themselves. I have given up trying to buy used OEM hinges cause they are usually worn as bad or worse than what I already have. Don't really want to use aftermarket either. I believe I can do this myself, my biggest concern is being able to rivet two hinge arms together and still have movement when I'm done. In other words, not rivet them too tightly.
So, has anyone done this? And if so, could you give me any tips? Thanks.
Steve Cole is offline   Reply With Quote
Old 03-31-2015, 02:37 PM   #2
geezer#99
geezer#99's Avatar
Re: Anyone successfully rebuilt their hood hinges?
I've never taken them apart to rebuild, but I've squeezed them in a big vice to tighten them up.
Old 03-31-2015, 02:41 PM   #3
67 cst swb
67 cst swb's Avatar
Great idea. I am going to have to try that.
My Trucks:
1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project
1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver
1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck
1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck
2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White
67 cst swb is offline   Reply With Quote
Old 03-31-2015, 08:51 PM   #4
Steve Cole
Unfortunately, squeezing the pieces in a vise will not fix elongated rivet holes. It may help if there was a gap between the two pieces but that is almost never the case.
Old 03-31-2015, 11:04 PM   #5
Billhilly
Billhilly's Avatar
http://67-72chevytrucks.com/vboard/s...=217490&page=7 We start talking about it on this page, and there is pictures of the finished products on the next page. Willie Wilson was super helpful. I dismantled, built up and reamed out holes. Zinc plated and painted, then reassembled. He (Willie) will do it all for you. I'm sure I saw somewhere (Rock Auto?) that you could still buy OE, well one side anyway! Let me know if you have any questions.
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
Old 04-01-2015, 10:08 AM   #6
Steve Cole
Thanks for the reply Billhilly! Is there a trick for pressing these rivets without getting them too tight for proper movement?
Old 04-01-2015, 11:28 AM   #7
Diggers Dad
I wedged in thin 1/2 inch E clips to the rivets. Don't know how long it will last but very easy to do.
Mike
Diggers Dad is offline   Reply With Quote
Old 04-01-2015, 12:23 PM   #8
Steve Cole
Mike
Not sure I am following you Mike, are you saying you installed the E clips between the arms? Was that to take up slack on worn hinges? Or installed temporarily to keep the arms from being pressed together too tightly during riveting?
Old 04-01-2015, 12:32 PM   #9
Diggers Dad
Steve Takes up slack from worn hinges/rivets. The shoulder on the rivets are 1/2 inch. The E-clips just snap around the shoulder. Not perfect but I'll see how long it lasts.
Mike
Old 04-01-2015, 01:05 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Anyone successfully rebuilt their hood hinges?
Why not let Willie do it. It's been 3-4 years on mine and they look great and not any play at all in them so far. He does great work and you can't beat his prices.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-01-2015, 03:16 PM   #11
Billhilly
Billhilly's Avatar
No real trick, but I did take everything to a friends shop. He did the pressing while I held everything and 'wriggled' the arms and made the call on when to stop pressing. Worked out ok. Willie does send a couple extra rivets in case you overcook it!
1972 K2500 Long Box
400/350
Old 04-01-2015, 03:20 PM   #12
Steve Cole
Willie wants $150 to bead blast the hinges and replace the rivets. That seems like a fair price but it is $150 more than I have to spend right now. I can buy rivets online for a fraction of that cost. I have access to drills, reamers, bead blasters and a hydraulic press. I want to do this myself, if it doesn't work, I'm not out much money. I was just looking for tips from someone who may have done this before.
Old 04-01-2015, 03:24 PM   #13
Billhilly
Billhilly's Avatar
If you have access to that stuff you'll be fine. If I can do it, I'm sure you can!
1972 K2500 Long Box
400/350
Old 04-01-2015, 03:30 PM   #14
Steve Cole
I contacted Willie and he said he doesn't sell just the rivets. Did you buy rivets from him?
Here is his reply...
Steven,
We do not sell rivets for repair, as every hinge set is different in the size of the rivet hole and the metal thickness, so no way to have a generic truck rivet. We can rebuild both your hinges for 150.00, plus shipping. That gets them back in bare metal or primer and that is as cheap as we can do. The only way to get it cheaper is to have them media-blasted before they arrive here and I will pay the return shipping charges. Thanks,
Old 04-01-2015, 03:35 PM   #15
Steve Cole
That is what I was looking for! Thank you. I would not have thought of wriggling the arms while pressing.
Old 04-01-2015, 03:44 PM   #16
Billhilly
Billhilly's Avatar
Yeah, but it was a couple of years ago now. (My memory is going) but I wonder if it was an option on his website then. Obviously it has changed. There was another guy doing it as well. I'll have a look around.
Truck painter is here, gotta run!
1972 K2500 Long Box
400/350
