replacing rivets with bolts
Anyone ever do it? I know there is no reason for it but I might be picking up a rolling chassis and will be taking it all apart. I think it would look cool having some grade 8's holding it all together.
66 shorty ![]() |
Re: replacing rivets with bolts
hi you might have one reason to replace them if you weld close to one inch of a rivet.
i've done a few crossmember modification on my 63 C10 and i used grade 8 bolts with two washers and a nylon insert jam lock bolt everytime. |
Did my whole chassis in grade 8 wherever I removed rivets. And they are such a joy to grind out!!!
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
It's Better With Nitro
Yep, of the rivets I've removed for modifications, replacing damaged/corroded parts, I've used regular grade 8 nut/bolt fasteners.
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I think they stay a lot tighter with rivets. I sure don't remove them unless I have to, like with ball joint replacements. The bolts are no doubt strong but they don't fill the voids and shrink like a hot rivet does.
#7 | |
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ Last edited by Keith Seymore; 04-01-2015 at 07:47 AM. |
60-66 Nut
![]() ![]() Join Date: Mar 2007
I prefer to use the prevailing torque, all steel lock nuts.
![]() Join Date: Aug 2013
turn on a dime, are there any rivet kits i can use to replace cut out rivets? i was gonna shape the heads of grade 8 bolts to make it appear to be rivets. any help would be great!!!
#10 | |
![]() Join Date: Nov 2013
I'd hate to have something important fail while you're out on the road.
We'll burn that bridge when we get there My current project: Rust Therapy 62 C10 Numbers 6:24-26 |
And if the bolts ever became loose, youd be unable to tighten them too pimpston65.....
#12 | |
![]() Didn't take long but still a pain. I just did this two nights ago on my ebrake crossmember, had to remove it to fit my t5 in. Im bolting it back on with grade 8 3/8" bolts and nyloc nuts
My Jalopy - http://67-72chevytrucks.com/vboard/s...d.php?t=641102 |
#13 |
![]() Join Date: Aug 2008
I had the whole frame apart on my 66. Cut out every sibgle rivet. I redrilled through all the holes to 7/16 and used grade 8, 7/16-20 fine thread bolts with hardend flat washers and grade 8 nyloc nuts. I started with 3/8 but the 7/16 bolts can handle much more torque and thus imoart much higher surface contact friction.
The compromise is that these still dont work as well in shear as the rivets do. But I rrally didnt have any other choice unless I wanted to weld all the crossmembers to the frame. Its been holding up okay so far.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
#14 |
Button head cap screws have a rounded look like a rivet on the head if that is what you are looking for. I would drill the hole to be tight (5/8" for a 5/8" bolt) on the next size up bolt if you are wanting to go that route.
#15 |
That's not so bad....try the bellhousing crossmember with the cab installed. Best one yet!!!
#16 |
#17 |
Years ago I did some work on a Model A frame and cross member. I used a Chrysler wheel bolt with the dish in the head and welded it on to the end of a rivet snap. After heating the rivet red it did a really nice job of rounding the end.
But if I ever had to do one again I'd use the bolts. |
