Old 03-31-2015, 04:20 PM   #1
Red68ShortFleetside
LS engine ignition coil covers
I saw on Possmguts "disk brake backers or not?" thread a really neat LS engine ignition coil cover. Did he buy it or make it?
Ike
68 swb fleetside
heavily modified TPI engine. Ford AODE automatic (yes Ford!), 12 bolt 4:11 positraction rear axle, 4 wheel disc brakes, wood dash and LED instrumentation, BMW bucket seats, outside stock except for dark red paint.
Red68ShortFleetside is offline   Reply With Quote
Old 03-31-2015, 09:14 PM   #2
hugger6933
Re: LS engine ignition coil covers
I didn't see that thread. Did it make it kinda look like a Big Block? Holley makes some that makes it look like a rat motor. You could also go to Speedway motors and look there I saw some covers tonight while I was in the restroom doing "research". Jim
hugger6933 is offline   Reply With Quote
Old 03-31-2015, 09:37 PM   #3
cwheeler2584
clayton machine works make some really nice covers but a little pricey. went with the holley big block replicas for a smooth look personally
cwheeler2584 is offline   Reply With Quote
Old 04-01-2015, 08:21 PM   #4
MattPSU
MattPSU's Avatar
I'm also running Holley's Coil Covers. Lots of modifying to use them with a 5.3L truck motor in the stock position in my 72.
Matt Criswell - Lyman, SC
1972 Chevy Cheyenne SWB - Build: Porterbuilt State 1 Front & Rear, Bolt in Notch, McGaughys 2.5 Drop Spindles, Boyd Welding Fuel Tank
UPSTATE SC GM TRUCK CLUB: FACEBOOK WEBSITE
MattPSU is offline   Reply With Quote
Old 04-01-2015, 08:34 PM   #5
tommys72
tommys72's Avatar
I like the look of these
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 04-01-2015, 09:06 PM   #6
Andy4639
Old member
Andy4639's Avatar
Wink Re: LS engine ignition coil covers
I made mine and a friend painted it for me.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-02-2015, 09:23 PM   #7
cwheeler2584
I'm running mine on a 6.0 LQ4 using CPP stock location engine mounts but i have also cut out the entire stock firewall and made it to fit the covers tightly.... but your enigine bay looks very clean
