Old 03-31-2015, 06:32 PM   #1
jobrla
NP205 front output yoke bolts
Well, I seemed to have had another senior moment. After rebuilding my NP205 and my front axle and yokes. I can no longer find the 4 yoke-to-yoke bolts that holds them together. In all my research, no one seems to have these in stock or give me measurements. The closest I have come up with is..
Thread .312-24
Thread length 1.43" (1 7/16)
Any thoughts
Here is a pic of the yoke on the transfer case and axle
jobrla is offline   Reply With Quote
Old 03-31-2015, 06:56 PM   #2
jobrla
Re: NP205 front output yoke bolts
Okay, I have made a positive I.D that they are in fact 5/16 fine grade 8 bolts. Just now need to find the length
Old 03-31-2015, 09:02 PM   #3
1rippen6
I can measure one tomorrow
1rippen6 is offline   Reply With Quote
Old 03-31-2015, 09:25 PM   #4
67swb72klb
67swb72klb's Avatar
I have some 1-1/2" long
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-31-2015, 10:49 PM   #5
GMC-YA68
GMC-YA68's Avatar
Cut them down if you have to...
-Keegan-
'72 Jimmy 4x4 - 5.3/4L65E/NP205 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=663780
GMC-YA68 is offline   Reply With Quote
Old 04-01-2015, 09:05 AM   #6
jobrla
I tried a 1 1/2 bolt but will not let you line up straight to start. Head of bolt touches transfer case collar. Can't cut a grade 8 bolt.
Old 04-01-2015, 08:49 PM   #7
1rippen6
Looks to be close to 1 3/8 maybe the 1 7/16 from your first post is correct.
Old 04-01-2015, 08:51 PM   #8
1rippen6
You could probably run a nut on and grind the end down to the correct length and then back the nut off to clean the threads up.
Old 04-01-2015, 09:33 PM   #9
jobrla
Thanks guys, as always, you come through
