Old 03-31-2015, 06:39 PM   #1
74baggedbug
Column shifter swap
Any idea of how hard it is to swap out the factory shifter to a billet? A buddy said it's easy and all I gotta do is remove the pin and swap them out.. Tried the search option but no luck... Thanks
74baggedbug is offline   Reply With Quote
Old 03-31-2015, 08:18 PM   #2
BigBassFiddle
Re: Column shifter swap
Use a hammer and a punch to knock the pin on the stock shifter where the shifter mounts to the collar on the column. Super simple.
BigBassFiddle is offline   Reply With Quote
Old 03-31-2015, 08:51 PM   #3
74baggedbug
I did that and sure was super simple.. This shifter input shaft is to short so back to the drawing board!! Gonna take the factory shifter and figure out a way to use that shaft that goes into the column on the billet shifter.. Either machine it down or weld it
Old 03-31-2015, 10:25 PM   #4
Boog
laying low
Boog's Avatar
Do you have a tilt column? The shift levers are different between a tilt and non tilt column. I think that looks like a tilt column shift lever.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 03-31-2015, 10:42 PM   #5
74baggedbug
No I don't have a tilt column.. I should be able to install it in the next few days.. Gonna see what my buddy who's a machinist can figure out
