Old 08-28-2003, 08:42 PM   #1
Rod
Seen radio knobs like this?
I asked this question a while back but took some pics today.
Anyone seen radio knobs like the chrome one in this pic.. it compares 67 radio knob and washer with some I took from a different 67... note the solid recessed washer on the left and the more common recessed washers with the cut outs on the right.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 08-28-2003, 09:27 PM   #2
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Rod,I have not seen any lately.
I' P/M'd you though.
Bob.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 08-28-2003, 09:41 PM   #3
junkyardjohn
junkyardjohn's Avatar
Lightbulb
YEP ROD .... THOSE SURE LOOK LIKE THE KNOBS, I PULLED OFF OF A 68 IMPALA AWHILE BACK. (CAN YOU SAY PACKRAT??)
junkyardjohn
69 1 TON TOW TRUCK //
84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES//
LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS)
DON'T RENT U-HAUL
ALWAYS TELL THE TRUTH
IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST
junkyardjohn is offline   Reply With Quote
Old 08-28-2003, 09:46 PM   #4
Rod
Yep... they sure do... are they different in the way they mount .... my chromies have a slot in the back to fit on the shaft. Kinda like a typical newer style knob. While the normal truck ones have a hole with a compression ring in them to mount on the radio shaft. Rod
Old 08-28-2003, 10:03 PM   #5
junkyardjohn
YEP -- IT'S DIFFERENT ALLRIGHT.
junkyardjohn
DON'T RENT U-HAUL
Old 08-28-2003, 10:51 PM   #6
oldsub86
I have a Motorola radio that fits the truck that has the chrome knobs. Have not installed it yet but I am told it works.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 08-29-2003, 07:16 AM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
The reason for the slots, if I recall correctly, was for an adjustment screw that was accessible thru that slot, on the front of the radio. I think it was to allow for tuning the antenna to the radio...something that AM radios needed. FM radios relied on a fixed-length antenna, later on.
If anyone else remembers, let me know.
Member Nr. 2770
Old 08-29-2003, 08:01 AM   #8
Woody
Those style of knobs were on Oldsmobiles in the late 60's. Also probably on Pontiacs, & Buicks.
Woody is offline   Reply With Quote
Old 08-29-2003, 10:54 AM   #9
junkyardjohn
SORRY CHEVYLORAY ...... THESE SLOTS ARE ONLY HELPFUL TO HOLD THE KNOBS ON.
junkyardjohn
DON'T RENT U-HAUL
Old 09-30-2003, 10:01 PM   #10
Rod
Jose found a set like the ones I found also...note the different type back slot.
