03-31-2015, 08:17 PM | #1 |
LS3 416ci/4l85e
getting close to swapping LS3 416ci/4l85e combo. I was wondering if any one has recommendation on a stand alone transmission controller. like MSD, tci, pcs simple shift, painless torq? I already have harness and ecm set up for standalone tcm. so I don't think a stock one will work. thanks in advance.
04-01-2015, 02:06 AM | #2 |
meowMEOWmeowMEOW
Re: LS3 416ci/4l85e
I've only ever seen the TCI one used in person. It didn't seem bad to setup, and our TCI rep had it controlling a 4l80e very nicely. What standalone ecm are you running that requires a seperate trans controller? (MS?, eTool?)
04-01-2015, 11:08 AM | #3 |
Re: LS3 416ci/4l85e
what ECM is your harness setup for?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-01-2015, 03:53 PM | #4 |
Re: LS3 416ci/4l85e
I had it programmed for a stand alone tcm. harness set up that way to.
04-01-2015, 03:54 PM | #5 |
Re: LS3 416ci/4l85e
04-01-2015, 03:56 PM | #6 |
Re: LS3 416ci/4l85e
If they would have used an E67 or E92, they have the capability of controlling a 4L85 tranny.
04-01-2015, 07:30 PM | #7 | |
Re: LS3 416ci/4l85e
Adding the T42 to your existing set-up is EASY!! The only 2 circuits you will have to mess with on the engine harness are the 2 CAN/Bus wires at the DLC, The CAN/Bus will come out of the ECM to the TCM, Then out of the TCM to the DLC...Instead of out of the ECM straight to the DLC. Wire up the Powers & Grounds, ISS, VSS, Range switch, Then the harness to the trans plug. Factory TCM's can be tuned with HPTuners/EFI Live on top of factory support & diagnostics, I'm not knocking aftermarket controllers, They have their place.....Just not on LS engines. |
04-01-2015, 09:20 PM | #8 | |
Re: LS3 416ci/4l85e
04-01-2015, 10:18 PM | #9 |
Re: LS3 416ci/4l85e
Note to me !
Review when you do your next swap with LS3
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 Last edited by solidaxel; 04-01-2015 at 10:18 PM. Reason: sp |
04-01-2015, 10:55 PM | #10 |
Re: LS3 416ci/4l85e
clinebarger, the CAN/bus lines you talk about is this the system that uses 120 ohm resistors at both ends of the circuit? If so, is it built into the modules or do you add them at each end or am i thinking of a newer system? Thanks in advance.
04-01-2015, 11:26 PM | #11 |
Re: LS3 416ci/4l85e
Here are some '08 6.0L/4L80E CAN/Bus diagrams.
04-02-2015, 10:16 AM | #12 |
Re: LS3 416ci/4l85e
Thanks for the wiring harness info. It looks like the CAN/bus start in the engine controller, daisy chained through every module and ends in the trans controller, and the dlc connection is "tee-ed" into the bus lines. Thanks again.
04-02-2015, 07:07 PM | #13 | |
Re: LS3 416ci/4l85e
The above diagram is a '08 Express Van 6.0L/4L80E, The ECM & TCM have 120 ohm resistors built in, This particular set-up is "tee-ed" in, But not all are like this. **Anybody using these diagrams for other models.....Be aware there are differences** I cut the diagram in half, Maybe you can read it now. |
04-02-2015, 07:16 PM | #14 |
Re: LS3 416ci/4l85e
'11 Chevy C/K 4.3L/4L60E & 6.0L/6L80E
It is wired like I stated earlier, Starts at the ECM goes through the TCM, Then to the DLC |
04-02-2015, 07:21 PM | #15 |
Re: LS3 416ci/4l85e
These diagrams can't take up that much space...Their black & white? I can post giant pictures but not diagrams
Cut in half... |
