Old 03-31-2015, 08:33 PM   #1
Ratpick
Upper Door Hinge problem - swing-open limiter pulling thru
On '67 C10... Pass door has been swung all the way open too many times. Upper hinge where limiter/stopper located is pulling through on inside bolt. Outside two bolts still have some sheet metal around them. I think I'll be cutting an access hole in front of window reg is and forming a piece to fit across and trying to weld it in, inside the door.
I've been searching and don't see a trick for this. Just wondering if you had advice and what worked or what was overkill.
Ratpick is offline   Reply With Quote
Old 03-31-2015, 08:35 PM   #2
Ratpick
Re: Upper Door Hinge problem - swing-open limiter pulling thru
Dadgum that one was sideways. And iPhone not doing two at once. Here's inside area and it contour that I have to fit.
Old 04-06-2015, 09:13 PM   #3
Ratpick
This was very tricky to reach in with welder and try to see what I was doing. But still easier than changing door.
Old 04-06-2015, 09:14 PM   #4
Ratpick
Why the heck all my pics turning sideways when I upload? This site and Siri don't jive?
