Old 03-31-2015, 11:11 PM   #1
Dragun12
Dragun12's Avatar
315/35-20 on 20x10 up front?
Ok I've been hunting the net for days and i haven't found anything, but would anyone know if I could squeeze a set of 315/35-20 on a 20x10 with a 5" off set on the front of a 72 c10 with cpp off set modular spindles?
it has a 3/5 drop and I have a nice 40 mile twisty canyon stretch of road at the end of my drive home and I will be running that same tires and wheels all the way around, because the truck see around 120-150 miles in total a day so I néed to be able to rotate them
Dragun12 is offline   Reply With Quote
Old 04-01-2015, 03:38 PM   #2
Domer
Domer's Avatar
Re: 315/35-20 on 20x10 up front?
ive seen 335/20-18's done on the front.. but that c10 was really built.. im running a 245/40-20 right now, and i can turn till i hit my control arm.. and thats at about 8" or so drop in the front.
Domer is offline   Reply With Quote
Old 04-01-2015, 07:35 PM   #3
Dragun12
Dragun12's Avatar
Wow 8 drop in the front, did you take out the inner fenders and is it static?
Old 04-01-2015, 09:53 PM   #4
Domer
Domer's Avatar
Static yes, I notched my cross member 3" and have 2 1/2" drop spindles. That's 5 1/2" with stock springs still. I have an unknow drop spring right now in there. So I'm guessing between 2-3" on the spring. And I am gonna cup the lca for another 1 1/2" to get my lca in spec. Going for a handling setup.
Old 04-02-2015, 12:22 AM   #5
Dragun12
Dragun12's Avatar
Yeah I'm going for a handling set up as well but being that low is it hard to daily driver
Old 04-02-2015, 08:29 AM   #6
Domer
Domer's Avatar
Mine isn't a daily. It's just a toy. But I see those ricers running around with plastic bumpers 1"-2" off the ground. So with some good eyes it could be done.
Old 04-02-2015, 11:25 AM   #7
raic65
raic65's Avatar
I have 19x12s with 345/30-R19s. However it is on a 66. If you'd like to see look at post #324.
http://67-72chevytrucks.com/vboard/s...74#post6586374
raic65 is offline   Reply With Quote
Old 04-02-2015, 02:43 PM   #8
Domer
Domer's Avatar
raic65, you don't live too far from me. Im out in Lakeside, and work down at 32nd st.
edit... thats an impressive tire under that thing.. i cant go quite that wide as i am tucking a few inches of rim..
Old 04-02-2015, 02:45 PM   #9
Domer
Domer's Avatar
on a second thought, you should come by, and let me see if i can fit your wheels under my setup..
Old 04-02-2015, 09:23 PM   #10
Dragun12
Dragun12's Avatar
That is awesome raic65 how does it handle and what's the offset on your wheels
Old 04-02-2015, 11:57 PM   #11
tinydb84
tinydb84's Avatar
How do you fit those up front????
David
Instagram: myfabguy
Old 04-03-2015, 10:25 AM   #12
raic65
raic65's Avatar
Domer, I live in Bonita and work in La Jolla. I did go through a few sets of wheel spacers though to place them where I needed them. There is one downside though, really not good at making u-turns anymore. I may be in the El Cajon area this weekend and might be able to meet up. Send me a PM.
Dragun, IMO it handles pretty well. It sure doesn't handle like a truck anymore. Sticks going around corners. The wheels are factory C6 Grandsport rear wheels. I used hubcentric wheel adapters to give me the correct back spacing I needed.
Tinydb84, The short answer is wheel adapters. However, with stock lower arms, you loose a lot of turning radius. I did run the setup with stock arms for a while by clearancing the back side of the control arm where the wheel makes contact, but you still don't get back enough for parking lot driving (Always took 2 shots to pull into a spot). I was able to get most of it back with a lower control arm change. It took the right lower control arm design though. I looked into Porterbuilt, Ride Tech, CPP, and Hotchkis. I ended up going with Hotchkis based on the shape of the backside tube compared to the other arms. One thing I haven't mentioned is I also did a brake swap. You can see the brake swap here.
http://67-72chevytrucks.com/vboard/s...22#post5891322
Old 04-03-2015, 12:09 PM   #13
raic65
raic65's Avatar
Here's a working link on the brakes.
Old 04-03-2015, 07:45 PM   #14
Dragun12
Dragun12's Avatar
Wow awesome setup, what thickness of spacers are you running in the front? I seen your old 18x9.5 front wheel setup you ran a 1.75" spacer l.
Old 04-03-2015, 10:47 PM   #15
raic65
raic65's Avatar
I'll need to double check, but I think it was 2.75"
Old 04-03-2015, 11:03 PM   #16
Dragun12
Dragun12's Avatar
Cool so 2.75 front and 2.50 rear and I found the grand sport wheel on jegs 303.99 is an awesome price but the price of the tires stings a little
Old 04-07-2015, 02:58 PM   #17
raic65
raic65's Avatar
I took a measurment on the front adapters and they are 2.5" thick. I do remember the tire price stinging depending on how long we wanted the tires to last. The current set I have on the truck are michelins and I think they ran around $1400 mounted and balanced. I did have Nitto Invos on previously and I remember them being around $900 I think.
Old 04-07-2015, 09:17 PM   #18
Dragun12
Dragun12's Avatar
I'm totally on board with a 345/30-R19s now and sorry to ask so much how do you think the porterbuilt arms would work
Old 04-08-2015, 10:55 AM   #19
raic65
raic65's Avatar
I'm not sure. It should be better than stock control arms. I found a couple of pictures for comparison. When I made the descision, it appeared IMHO that the Hotchkis arms provided more room based on where the tube intersected the lower ball joint and the angle of the tube between the lower ball joint to the frame mount (when looking down at the control arm).
Old 04-08-2015, 07:58 PM   #20
Dragun12
Dragun12's Avatar
Hu that's good information from the looks of it and cost I'm thinking that porterbuilt arms are going to do the trick and hotchkis has I front shock relocator that I really like so hopefully in a few months I can start adding to this post and thank you very much raic65 all your info helped a ton
Old 08-26-2016, 12:26 AM   #21
sharkskinman
245/50/20
Longer lug studs from flaps
20x9 et38 Helo Kick wheels
½" spacers all 4 ..clear axle ends in rear making et26
Just clears outside of stepside box
At Least 2" to to fender metal
Will change spacers for 1" spacers in the rear that have lug nut holes and more lug bolts for 6x5.5
But just picked up a set of 20x8 100 spoke (rusty and perfect) Player Wire Wheels with I believe et0 or so
With 245/60/20s I will be able to still lower it wherever I want
there are a couple tire size calculators on the interweb that will help you figure out what will fit
sharkskinman is offline   Reply With Quote
Old 09-02-2016, 02:18 PM   #22
Domer
Domer's Avatar
Here is my setup, 305/30-20 on 20x10 on all 4 corners. The wheels have 50mm backspacing. I am running a 1.25" spacer on the front, but can shave that down to 1". Only because my wheels are designed for unit bearings and our hub sticks out to far.
Project Roxy...
Shes Bad, Low, and Blown...
http://67-72chevytrucks.com/vboard/s...d.php?t=673333
Old 09-12-2016, 04:46 AM   #23
Dragun12
Dragun12's Avatar
Wow it's been a long time since I've been on here and here it goes I got a new daily driver a little FRS which has given me time to decide what to do with my 72 and I've decided the truck is going to get fully built and it's going to get 335/30-18s all the way around its going to take a long time, bills and life you guys know what's up and Domer your truck is sick
