04-01-2015, 10:42 AM | #1 |
Power steering pump for ac delco 36-18429 Rack on Must ll kit
I have one of these steering racks rs) which are commonly used on Mustang ll kits and wondering what pump/part number to use for a PS pump.
I'm running a 350 SB & I have also seen a reference to using a GM Type 2 Pump? Any recommendations? Last edited by Hampshire; 04-01-2015 at 11:06 AM. |
04-01-2015, 12:03 PM | #2 |
Hollister Road Co.
Re: Power steering pump for ac delco 36-18429 Rack on Must ll kit
You can use either pump but you may need a pressure reducer kit. Mii rack use about 300 psi less pressure than a GM pump puts out. Make sure you don't get a pump that's for Hydraboost brakes. Borgeson has the pumps , reducers and hose kits for MII to GM pump
04-01-2015, 12:06 PM | #3 |
Speedway also sells a reducer and fitting for G M pumps
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
04-01-2015, 12:21 PM | #4 |
use any 1970 to 2000 gm pump, they're basically all the same
you'll need the flow reducer as stated but... why put an oversized gm pump on a ford rack that needs the flow reducer while my truk does have the ford rack and gm pump, if i had it to do over i'd put a ford pump on
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
04-01-2015, 12:30 PM | #5 |
Very helpful, guys - thanks for responding
04-01-2015, 04:21 PM | #6 |
I have a MII rack, no pump yet. Is there a particular Ford pump I should get?
04-01-2015, 04:30 PM | #7 |
I called Borgeson today. They are right in my backyard & have a reduced pressure GM pump for my rack + short or long water pump brackets, etc. (or you can buy the flow reducer/shim kit from them for your pump GM/saginaw).
http://www.borgeson.com/xcart/catalo...-p-1-c-83.html Last edited by Hampshire; 04-01-2015 at 05:00 PM. |
04-01-2015, 04:37 PM | #8 |
I'd rather spend 30 something dollars for the reducer valve than 30 something hours trying to figure out how to cobble brackets to put a Ford pump on a GM engine. Ford even went to Saginaw pumps in later years.
Borgson makes a shim kit that you can reduce the pressure in your pump with too http://www.borgeson.com/xcart/catalo...p-1-c-133.html
Founding member of the too many projects, too little time and money club. My ongoing truck projects: 48 Chev 3100 that will run a 292 Six. 71 GMC 2500 that is getting a Cad 500 transplant. 77 C 30 dualie, 454, 4 speed with a 10 foot flatbed and hoist. It does the heavy work and hauls the projects around. Last edited by mr48chev; 04-01-2015 at 04:44 PM. |
04-01-2015, 07:14 PM | #9 |
I put the borgeson kit in my gm pump took 10 minutes and will allow you to set the pressure softer or firm depending how many shims are installed. easy directions
04-01-2015, 08:20 PM | #10 | |
Are Ford pumps aprox the same price?
04-02-2015, 01:42 PM | #11 | |
i'd think any mid 70s mustang or cougar pump would work fine as for the bracket? i made all of my brackets anyway gm, ford, mopar would be as easy as the other to fabricate that's one way to keep cost down 2 plates, some tubing and a few bolts
04-02-2015, 04:02 PM | #12 |
Any pictures of a Ford pump, or is that Saginaw pump what Ford uses these days?
