04-01-2015, 11:05 AM | #1 |
Blinker Issues
One of my winter projects was to replace a faulty wire harness in the steering column of my 63. I ordered a replacement switch and harness from LMC. While I was at it I replaced the column bearings too. (3spd on the tree)
Now when I turn on the signals - the right side cancels just fine. the left signal is acting strange. The front signal will stop blinking when the wheels straightens out and the turn signal arm returns/cancels to the center but the left rear keeps flashing and I can hear the flasher noise. I have to jiggle the handle to the right signal in order for it to stop. Anyone ever had this happen? Know a fix? Any help would be greatly appreciated. Electronics is not my strong suit. |
04-01-2015, 11:33 AM | #2 |
Re: Blinker Issues
The aftermarket turn signal units behind the steering wheel are very cheaply made. I had problems with the one in my 66. The way the plastic is molded around the switch contacts isn't very good. Mine was grounding out and doing weird things. When I pulled it out I could see how it was failing. I went and bought an "original gm" switch from Classic Industries and wow, what a big difference in quality. It did, however, cost nearly 4 times as much. I'm not sure if they make the original type for the 60-63 pickups but I'd try to find an original used one in good shape if they dont.
Jason M. @argonaut62 1972 K5 Blazer CST, Turquoise 1966 K20 Short Fleet Pickup, Big Ugly 1964 C10 Short Fleet, Gertrude 2001 Porsche 911 Carrera 1996 Ford Bronco XLT 1980 Jeep Wagoneer 2008 Honda CBR1000RR 2005 Honda RC51 1981 Honda CB750C No dis-assemble Johnny Five! No dis-assemble! |
