Old 04-01-2015, 12:00 PM   #1
Iceburgh
Iceburgh's Avatar
Vehicle speed Output Circuit
Can anyone tell me what this does.
I have it coming out of port 50 on the red terminal.
Not sure if I need it for my build.
Thanks in advance
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 04-01-2015, 03:17 PM   #2
dayj1
Re: Vehicle speed Output Circuit
Thanks in advance
It's the speed signal output from the PCM that feeds an electric speedometer. The default pulse rate is 4K pulses per mile, but I believe that can be changed on a Gen III.
dayj1 is offline   Reply With Quote
Old 04-01-2015, 05:53 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
If your running an OBD-powered gauge setup, you won't need this wire. If you want to hook up an aftermarket speedo that is electric, then you use this wire as the signal. On GenIII's you can modify the VSS resolution through HP Tuners.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-01-2015, 11:13 PM   #4
68c10airstream
68c10airstream's Avatar
I used the vss output from the pcm to now run a converted stock speedo and to run a gm cruise module
68c10airstream is offline   Reply With Quote
