Old 04-01-2015, 01:25 PM   #1
fatblockvelle
fatblockvelle's Avatar
blazer seat help please...
just picked up a 1971 blazer. has diff seats in it... what years are the same??? i need some , are they the same 69-72?
fatblockvelle is offline   Reply With Quote
Old 04-01-2015, 03:16 PM   #2
briank
Re: blazer seat help please...
Yes but the pattern is different depending on the year and if its a cst or plain jane. There was also slightly wider utility buckets as well......I dont think they make seatcovers for those. You will have to have those made.
briank is offline   Reply With Quote
Old 04-01-2015, 03:27 PM   #3
fatblockvelle
thank you... anybody else have more info??
Old 04-01-2015, 04:02 PM   #4
Classic Bowties
Always on the hunt...
We've had a couple sets of bucket seats over the years, I can maybe help with some saved file pictures showing some of the seat shape and bracket differences. If wanting sport buckets and if trying to look OE original in your 71, and also to have all the correct mounting hardware you would need to find a front bucket seat setup out of a 71 or 72 K/5 or Jimmy, or also any A50 optioned 71/72 pickup or burb if you want to mess around with swapping the RH/pass side brackets. Here are a few pics to check out. Mel
Classic Bowties is offline   Reply With Quote
Old 04-01-2015, 04:05 PM   #5
Classic Bowties
Here was a setup removed from a 72 K/5...
Old 04-01-2015, 04:07 PM   #6
Classic Bowties
Here is a setup removed from a 71 K/5...
Old 04-01-2015, 04:09 PM   #7
Classic Bowties
And another setup out of a 72 K/5...
Old 04-01-2015, 04:10 PM   #8
fatblockvelle
wow... doesn't get much better than that!!!! THANKS!!!
Old 04-02-2015, 04:15 PM   #9
Chulisohombre
Chulisohombre's Avatar
Saved for later on. Good to see how they were so different.
72 3/4 ton blazer. 5 inch lift on 35 inch tires. 355 corvette engine with crane roller rockers, rv cam, edelbrock carb and intake with one inch spacer. Thrush Headers with flowmaster 40 duels. 4speed sm465 manual. 4 wheel disk brakes with Inboarded rear shock prerunner style mounts and shocks.
Chulisohombre is offline   Reply With Quote
